Kicad solder resist layer
erdem55
Joined Jan 30, 2021
7
Hi Guys,
I am new here.I designed pcb on 3 phase inverter circut with kicad, and then I send my gerber files to jlcpcb.They have solder line for high current, but Jlcpcb send to normal pcb not soldering line. I used to draw F.paste and B.paste layer. What if I made wrong?
At now I share my files with you
Please you say my wrong
Good day
panic mode
Joined Oct 10, 2011
5,034
if i understand correctly, you were trying to expose high current tracks through soldermask so that wetting by solder would increase layer thickness and ampacity. if so, did you look at the imported files? they clearly shows that all tracks are covered in solder mask (green). that would suggest that either solder mask files are not containing what you expect or that that import failed (unexpected file name or whatever).
