Keeping soldering area clean
John Bostwick
Joined Apr 12, 2017
Been soldering for a while now, first time posting, as I have a question on trying to keep a work area clean.
I do alot of through-hole pcb soldering at home and I'm constantly clipping the leads, which go flying every where. Is there a good fast way to keep the area clean as possible. I'm not even going to try to keep my 3d printing area clean, which I also get constant plastic strings all over the garage.
Any good advice is welcome.
djsfantasi
Joined Apr 11, 2010
9,237
I keep on hand, a several small strips of foam/sponge (not cellulose) with about a 6mm square cross section.
Then, before clipping any leads I pierce the foam with a lead. When cutting, the waste is trapped in the foam and easily cleaned up. No more flying leads.
KL7AJ
Joined Nov 4, 2008
2,229
If you could invent a self-cleaning bench, you will be fabulously rich....or not.
"Where no oxen are, the crib is clean, but much increase is by the strength of the ox." Proverbs 14:4. Evidently the old Bible dudes had the same problem. :)
dl324
Joined Mar 30, 2015
18,450
Welcome to AAC!
When I clip leads, I put my finger over the end of the lead to prevent it from flying off. If it stays between my finger and the clipper, I put it in the waste receptacle on my bench. Any that fall on the bench are cleaned up when I'm finished clipping.
Another method is to hold the board in/over a trash can when clipping.
AlbertHall
Joined Jun 4, 2014
12,640
When I was working in an electronic servicing workshop one of the technicians wanted to be sure that no bits of wire or solder on the bench could short the tracks on the switched mode supply he was working on and rested the board on his cigarette packet. Unfortunately the packet was metal foil covered. It did not end well for either the power supply or cigarette packet :eek:
OBW0549
Joined Mar 2, 2015
3,565
I just restrain the leads while they're being clipped to prevent them from flying all over the place-- either by pressing them against the board with a fingertip, or by holding them between my fingers.
I layed a $1000 thermometer that I was fixing (replacing the huge processor) on aluminum foil (anti-static right?) and powered it up sitting on the foil. It ended OK.
Agree: The cutters pictured don't shoot the leads.
Vacuum cleaner and component leads do not play well together. Ask me how I know...
Might depend on the vacuum cleaner. Shop-vacs with a debris element might fair better than a paper bag cleaner.
Sensacell
Joined Jun 19, 2012
3,787
Take a pair of standard diagonal cutters- clean well with alcohol.
Fill the inside of the jaws with RTV silicone- allow it to cure thoroughly.
Cut the silicone with a sharp razor blade, directly in line with the jaws.
The silicone acts as a 'soft jaw' to hold the wire bits, preventing them from flying.
DickCappels
Joined Aug 21, 2008
10,662
I just aim the leads toward the middle of the room, which has a tile floor. Every now and then I sweep them up and toss them. This technique is not compatible with carpeted floors :)
35,059
As Robin Mitchell points out in post #4, you can buy side cutters that have a safety clip.
When you snip the leads, the loose end is held on to the clip which then drops (into a waste bucket) when you open the snips.
No more projectile leads.
