Keeping duty cycle constant while changing frequency
ane1983
Joined Jul 15, 2024
55
Greetings colleagues. I would like help with the design of an oscillator with a variable frequency between 10 and 200 Hz and a duty cycle between 1 and 15%. I was searching but the post was already deleted because it was too old.
sghioto
Joined Dec 31, 2017
8,751
Was this oscillator using a 555?
ane1983
Joined Jul 15, 2024
55
This is what it says in the old post; but I don't access any.
--Actually, a 555 will do it, but not with that schematic. I've shown how to make duty cycle and frequency totally independent, it is pretty easy. See Figure 4.3 of LEDs, 555s, Flashers, and Light Chasers, it works extremely well and can do a full 100% with careful component selection.---
ane1983
Joined Jul 15, 2024
55
Greetings. Thanks for your time; but the circuit I am looking for is one that can vary the frequency and useful cycle, but after establishing the useful cycle, when the frequency varies it does not vary.
ane1983
Joined Jul 15, 2024
55
the idea is to compare setpoint with triangular or saw tooth signal. then one can change the frequency of the triangular wave oscillator and since amplitude does not change, PWM output duty remains the same:
https://forum.allaboutcircuits.com/threads/bill-marsdens-pwm-circuit.44757/
of course one can can have more than one opamp or comparator available so one could replace 555 with it..
I don't know why I can't see the diagram. Could you please share it if you see it. Maybe by looking at it you will understand better.
Papabravo
Joined Feb 24, 2006
22,111
AFAIK, posts on this forum are never deleted. Some of mine from 2006 are still here.
panic mode
Joined Oct 10, 2011
5,250
here is the image from link
R1 is used t ocontrol the frequency.
R5 is used to control duty cycle.
both controls are independent of each other.
ane1983
Joined Jul 15, 2024
55
Sorry if you don't understand something, I have little command of English and I use a translator most of the time. I'll show you what you show me
AnalogKid
Joined Aug 1, 2013
12,276
What you want can be approximated with a single 555, but not over a 20:1 frequency range.
The circuit in #11 should do that. Here is the schematic as an image.
It also can be done without a 555, using a dual opamp (LM358) or dual comparator (LM393). You don't say if you need the circuit to run on a single supply or dual supplies. The first two schematics here cover both. Note that the second schematic can be improved.
https://www.homemade-circuits.com/op-amp-oscillator-circuits-explained/
ak
