K Thermocouple conversion by polynomial conversion formula
Vindhyachal Takniki
Joined Nov 3, 2014
598
Was writing code to convert thermocouple k type conversion formula for best accuracy. Goal is to use polynomial functions and not the table or other method, that I will write in next code. Currently accuracy is concern. Below is my code, any one found any issue in that?
Currently i have simulated only by putting different millivolt values & cold junction value as 0c. Any way it can be improved further for accuracy or any other error in code.
Code:
1. Convert the cold-junction temperature (TCJ) to a voltage (VCJ)
2. Add the cold-junction voltage to the measured thermocouple voltage (VCJ + VTC)
3. Convert the summed cold-junction voltage and thermocouple voltage to the thermocouple temperature
(TTC)
#define float32_t  float
const float32_t ci_i0_below0 = 0.000000000000E+00;
const float32_t ci_i1_below0 = 0.394501280250E-01;
const float32_t ci_i2_below0 = 0.236223735980E-04;
const float32_t ci_i3_below0 = -0.328589067840E-06;
const float32_t ci_i4_below0 = -0.499048287770E-08;
const float32_t ci_i5_below0 = -0.675090591730E-10;
const float32_t ci_i6_below0 = -0.574103274280E-12;
const float32_t ci_i7_below0 = -0.310888728940E-14;
const float32_t ci_i8_below0 = -0.104516093650E-16;
const float32_t ci_i9_below0 = -0.198892668780E-19;
const float32_t ci_i10_below0 = -0.163226974860E-22;
const float32_t ci_i0_above0 = -0.176004136860E-01;
const float32_t ci_i1_above0 = 0.389212049750E-01;
const float32_t ci_i2_above0 = 0.185587700320E-04;
const float32_t ci_i3_above0 = -0.994575928740E-07;
const float32_t ci_i4_above0 = 0.318409457190E-09;
const float32_t ci_i5_above0 = -0.560728448890E-12;
const float32_t ci_i6_above0 = 0.560750590590E-15;
const float32_t ci_i7_above0 = -0.320207200030E-18;
const float32_t ci_i8_above0 = 0.971511471520E-22;
const float32_t ci_i9_above0 = -0.121047212750E-25;
const float32_t a0_above0 = 0.118597600000E+00;
const float32_t a1_above0 = -0.118343200000E-03;
const float32_t a2_above0 = 0.126968600000E+03;
const float32_t d0_i0 = 0.0000000E+00;
const float32_t d0_i1 = 2.5173462E+01;
const float32_t d0_i2 = -1.1662878E+00;
const float32_t d0_i3 = -1.0833638E+00;
const float32_t d0_i4 = -8.9773540E-01;
const float32_t d0_i5 = -3.7342377E-01;
const float32_t d0_i6 = -8.6632643E-02;
const float32_t d0_i7 = -1.0450598E-02;
const float32_t d0_i8 = -5.1920577E-04;
const float32_t d0_i9 = 0.0000000E+00;
const float32_t d1_i0 = 0.000000E+00;
const float32_t d1_i1 = 2.508355E+01;
const float32_t d1_i2 = 7.860106E-02;
const float32_t d1_i3 = -2.503131E-01;
const float32_t d1_i4 = 8.315270E-02;
const float32_t d1_i5 = -1.228034E-02;
const float32_t d1_i6 = 9.804036E-04;
const float32_t d1_i7 = -4.413030E-05;
const float32_t d1_i8 = 1.057734E-06;
const float32_t d1_i9 = -1.052755E-08;
const float32_t d2_i0 = -1.318058E+02;
const float32_t d2_i1 = 4.830222E+01;
const float32_t d2_i2 = -1.646031E+00;
const float32_t d2_i3 = 5.464731E-02;
const float32_t d2_i4 = -9.650715E-04;
const float32_t d2_i5 = 8.802193E-06;
const float32_t d2_i6 = -3.110810E-08;
const float32_t d2_i7 = 0.000000E+00;
const float32_t d2_i8 = 0.000000E+00;
const float32_t d2_i9 = 0.000000E+00;
void setup()
  Serial.begin(9600);
void loop()
    uint32_t err;
    float32_t tempc;
    err = thermocouple_tempc(54.819f, 0.0f , &tempc);
    Serial.print(err);
    Serial.print("     ");
    Serial.println(tempc);
uint32_t thermocouple_tempc(float32_t vtc_mV , float32_t cj_tempc , float32_t *tc_tempc_return)
    uint32_t err = 0U;
    float32_t vcj_mV = 0.0f;
    float32_t vsum = 0.0f;
    float32_t tempc = 0.0f;
//////////////// STEP-A cold-junction temperature (TCJ) to a voltage (VCJ)
/* convert cj_temp into mv by below equation
* E = sum(i=0 to n) c_i t^i.
* The equation above 0 °C is of the form
* E = sum(i=0 to n) c_i t^i + a0 exp(a1 (t - a2)^2).
    if(cj_tempc < -270.0f)
        err = 1U;  //cold-junction undertemperatyre
    else if((cj_tempc >= -270.0f) && (cj_tempc < 0.0f))
        vcj_mV =         ( ci_i0_below0  * pow(cj_tempc , 0U) )
                       + ( ci_i1_below0  * pow(cj_tempc , 1U) )
                       + ( ci_i2_below0  * pow(cj_tempc , 2U) )
                       + ( ci_i3_below0  * pow(cj_tempc , 3U) )
                       + ( ci_i4_below0  * pow(cj_tempc , 4U) )
                       + ( ci_i5_below0  * pow(cj_tempc , 5U) )
                       + ( ci_i6_below0  * pow(cj_tempc , 6U) )
                       + ( ci_i7_below0  * pow(cj_tempc , 7U) )
                       + ( ci_i8_below0  * pow(cj_tempc , 8U) )
                       + ( ci_i9_below0  * pow(cj_tempc , 9U) )
                       + ( ci_i10_below0  * pow(cj_tempc , 10U) );
    else if((cj_tempc >= 0.0f) && (cj_tempc <= 1372.0f))
        vcj_mV =         ( ci_i0_above0  * pow(cj_tempc , 0U) )
                       + ( ci_i1_above0  * pow(cj_tempc , 1U) )
                       + ( ci_i2_above0  * pow(cj_tempc , 2U) )
                       + ( ci_i3_above0  * pow(cj_tempc , 3U) )
                       + ( ci_i4_above0  * pow(cj_tempc , 4U) )
                       + ( ci_i5_above0  * pow(cj_tempc , 5U) )
                       + ( ci_i6_above0  * pow(cj_tempc , 6U) )
                       + ( ci_i7_above0  * pow(cj_tempc , 7U) )
                       + ( ci_i8_above0  * pow(cj_tempc , 8U) )
                       + ( ci_i9_above0  * pow(cj_tempc , 9U) )
                       + ( a0_above0 * ( exp(a1_above0 * pow((cj_tempc - a2_above0), 2U) ) )   );
    else if(cj_tempc > 1372.0f)
        err = 2U;    //cold-junction overtemperatyre
    else
        err = 3U;    //NAN or unknown error
//////////////// STEP-B cold-junction voltage to the measured thermocouple voltage (VCJ + VTC)
    if(0U == err)
        vsum = vcj_mV + vtc_mV;
        if(vsum < -5.891f)
            err = 4U;   //sum voltage falls below convertable range
        else if((vsum >= -5.891f) && (vsum <= 54.886f))
            //err = 0U; this is conevertiable range
        else if(vsum > 54.886f)
            err = 5U;   //sum voltage above convertable range
        else
            err = 6U;  //NAN or unknown error
//////////////// STEP-C vsum coversion to temperature
    if(0U == err)
        if(vsum < -5.891f)
            err = 7U;  //under-voltage for final ocnversion
        else if((vsum >= -5.891f) && (vsum < 0.0f))
            tempc =              ( d0_i0  * pow(vsum , 0U) )
                               + ( d0_i1  * pow(vsum , 1U) )
                               + ( d0_i2  * pow(vsum , 2U) )
                               + ( d0_i3  * pow(vsum , 3U) )
                               + ( d0_i4  * pow(vsum , 4U) )
                               + ( d0_i5  * pow(vsum , 5U) )
                               + ( d0_i6  * pow(vsum , 6U) )
                               + ( d0_i7  * pow(vsum , 7U) )
                               + ( d0_i8  * pow(vsum , 8U) )
                               + ( d0_i9  * pow(vsum , 9U) );
        else if((vsum >= 0.0f) && (vsum < 20.644f))
            tempc =              ( d1_i0  * pow(vsum , 0U) )
                               + ( d1_i1  * pow(vsum , 1U) )
                               + ( d1_i2  * pow(vsum , 2U) )
                               + ( d1_i3  * pow(vsum , 3U) )
                               + ( d1_i4  * pow(vsum , 4U) )
                               + ( d1_i5  * pow(vsum , 5U) )
                               + ( d1_i6  * pow(vsum , 6U) )
                               + ( d1_i7  * pow(vsum , 7U) )
                               + ( d1_i8  * pow(vsum , 8U) )
                               + ( d1_i9  * pow(vsum , 9U) );
        else if((vsum >= 20.644f) && (vsum <= 54.886f))
            tempc =              ( d2_i0  * pow(vsum , 0U) )
                               + ( d2_i1  * pow(vsum , 1U) )
                               + ( d2_i2  * pow(vsum , 2U) )
                               + ( d2_i3  * pow(vsum , 3U) )
                               + ( d2_i4  * pow(vsum , 4U) )
                               + ( d2_i5  * pow(vsum , 5U) )
                               + ( d2_i6  * pow(vsum , 6U) )
                               + ( d2_i7  * pow(vsum , 7U) )
                               + ( d2_i8  * pow(vsum , 8U) )
                               + ( d2_i9  * pow(vsum , 9U) );
            err = 8U;   //over-voltage for final ocnversion
        else
            err = 9U;  //NAN or unknown error
    if(0U == err)
        if(tempc < -200.0f)
            err = 10U;  //final calcualtions result in under temperature
        else if(tempc > 1372.0f)
            err = 11U;  //final calcualtions result in over temperature
        else
            *tc_tempc_return = tempc;
            //err = 0U; //final calcualtions ok
    return err;
Papabravo
Joined Feb 24, 2006
22,116
There is absolutely no point in making computations to 8 or 9 significant digits if the basic samples are ±2%. What are you thinking?
35,069
I once had to point out to an OEM that my 3rd order polynomial was a better fit than their 6th order polynomial which they advertised as being superior.
35,069
For the same reason, or was it something else?
Similar. They were fitting a non-linear sensor and were expounding that their higher-order polynomial gave a better fit. My argument was that the order of the polynomial should not go beyond the first acceptable fit. Going beyond is inviting unnatural oscillations.
Vindhyachal Takniki
Joined Nov 3, 2014
598
The code is only for getting best mathematical accuracy & demonstration by using polynomial function.
Later i will shift code to look up table. But I want to try code on polynomial also, just to use & experiment
So wanted to know if the method used is correctly used or somewhere i have done any mistake like converting cold junction temperature to voltage or any other.
This is just for fun/hobby. Made a loop on arduinio Leonardo to see what is max time it take to convert with fixed cold junction temperature 0C & varying thermocouple voltage from -5.891 to 54.886 with 0.01 step, all done in code only.
Max time to convert I get is 3776us even with this float intensive operation
Code is O3 optimized.
bogosort
Joined Sep 24, 2011
696
It's very likely that you can significantly reduce that conversion time by replacing all those pow() calls with repeated multiplications of the independent variable. For example, "a * pow(t, 4);" becomes "a * t * t * t * t;".
