The orientation of the "C in the middle" or the positioning of the +/- signs isn't important. Just the fact that one of the supply polarities touches the outer ring and the other touches the center conductor.The orientation of C in the middle is different but the negative and the positive are both on the same sides.
Thank you so much!The orientation of the "C in the middle" or the positioning of the +/- signs isn't important. Just the fact that one of the supply polarities touches the outer ring and the other touches the center conductor.
In the lower picture, they chose to draw a circle around the center conductor. That's okay too as the intent is clear.
Are you sure that positive line stops at central pin?m sorry for the low quality picture but on the 2nd picture the negative line stops at the outer ring
im sorry for the low quality picture but on the 2nd picture the negative line stops at the outer ring"C" orientation on second picture shows you minus at central pin.
