MaxHeadRoom
- Joined Jul 18, 2013
- 30,884
I use a Elmo document viewer instead of a microscope. It requires a laptop, but there's no lag. I bought mine used on Ebay for under $50.I have been eyeing a soldering microscope lately and I though a decent unit would climb into the thousands of dollars. this one seemed to have little or no lag in movement under the microscope.
I have one of those but it just does not magnify enough. in fact I just bought another one with a bigger base and 3* magnification on it but my glasses are 3.5 mag themselves and I still can't see past the end of my nose.For making up boards , I picked up one of these a while ago, they include a magnifier which is very handy.
Thank you verry much you have been most helpful. Looks like I have to figure it out with hopefully through hole components. If not I figure out how to mount and heatsink an SMD chip fortunately pins and 3 chances each not to cook it.I used it because I decided on a 2.5V cutout voltage for the Li-ion battery. If you wanted it to be higher, you could just use a higher voltage zener. I think the next value in my stock would have been 3.3V.
I chose MOSFETs because they'd dissipate less power than a BJT would.
AO3400 is rated for about 5A (at a higher threshold voltage). RDS is less than 20mOhms, so it would dissipate around 40mW at 2A. A BJT would dissipate watts at that current.
I started studying electronics in the mid-1970's and they didn't teach about MOSFETs. They were more curiosities at that time and didn't have anywhere near the capabilities they have now (in particular low threshold voltages, low on resistance, and high current capacities, and SMT wasn't that common back then). I learned about them pretty much on my own.
I tend to choose LM358 and LM393 (both around 50-year-old designs) when nothing better is required. LM358 is an opamp and LM393 is a comparator. Aside from the compensated gain stage of the LM358 and the open collector output on LM393, they're pretty much the same in functionality. That's why I suggested using a comparator for the opamp if you wanted to eliminate one of the ICs. Comparators are okay as slow opamps (due to the lack of compensation).
The opamp needed to allow a low input voltage and the input stage of LM358 is PNP, so ground is allowed. These days, users are more likely to opt for a rail-rail input device (and pay a buck or so for it vs $0.25 for LM358). The issue I have with rail-rail input opamps is that they usually use a complementary input. I worry about distortion in the crossover point. Early rail-rail opamps used charge pumps to operate the internal circuitry at more than the supply voltage. That could introduce noise. So I only use rail-rail input/output opamps when I need something better than LM358. It's hard to study modern opamps/comparators because manufacturers don't include detailed schematics. Also, you need to know the threshold voltage of the MOSFETs to analyze the circuit. You can't assume single Vt because multiple Vt's in the same device aren't uncommon these days. It just requires a different gate implant.
Similarly for LM393. I wanted the output to be able to go to the positive rail. Modern comparators usually have push pull outputs and can't quite get to the positive rail. The limitation on input voltage swing is addressed by using a 9V power supply LM393 allow around 7V, so getting to around 4.2V isn't a problem.
For home use, I think a hot air tool is better than a hotplate. With a hotplate, I'm concerned about exceeding the maximum allowed soldering times (like 10 seconds). For commercial applications, the equipment can control the temperature and time better.
For most of the SMT devices I use, I use a soldering iron and 0.015" solder wire. When I try using paste (without a stencil), I usually end up not using enough solder and have connectivity issues over time.
You can buy these adapters on AliExpress (used to be about a nickel each):If not I figure out how to mount and heatsink an SMD chip fortunately pins and 3 chances each not to cook it.
I have seen ones Similar to that but also had the 6 pin and 8 pint adaptors and a few I would not use loke BGA type chips the rebal type.You can buy these adapters on AliExpress (used to be about a nickel each):
I use solder wire on them.
The leads (called leadframes) cost about 10 cents each in quantity 100 when you can find them (I have of couple types available for 0.06" thick boards barter in the barter thread). You can also use right angle male headers.
ε = I·(r + R) = v + V -- where ε is EMF of the galvanic cell , r is the equivalent internal resistance of the galvanic cell , I is the current through the series circuit of battery and resistor R.So I wish to drain an 18650 battery and I wish to sense the voltage of the battery by using a point just after the 0.1ohm sense resistor I have chosen.
Sorry I didn't see the question about the voltage detector I chose. well I didn't actually choose it in fact it may well be as are a few of my parts the beat that the Zhenjiang market had to offer that day sent to me by a friend that went to China on a business trip. but It's what I had and the 2.8V choice was to stay clear of the 2.5 V or less that the manufacturer sites as the absolute lowest voltage a cell should drop to but it still shortens the life of the cell so 2.8 is as close as I will get to that voltage. and it drains the battery enough that a good estimate of the actual capacity of the cell when charged. That was really the only criteria I had. but the way you suggested does seem the better choice. Oh the 2 MOSFETS I went with are these both have Gate voltages of around 2 volts and have Ro of 2mOhm for the N channel and 4mOhms for the P channel. Both I am sure are Chinese knockoffs but I have 10 of each on order from mouser. more trustworthy I think.I see that from reading the text, but I was just looking at the schematic when I posted my questions.
What are the answers to the rest of my questions?
Are you determined to design this on your own? Or are you willing to take some circuit suggestions?
Do you already have the voltage detector IC? Do you have a problem with using a voltage comparator? It looks like the detector IC costs 2-3X what LM393 goes for. Plus, STM1061 appears to be SMT. 2.8V is neither the usual low voltage cutout (2.5V), or the conservative voltage (3.0V). Why did you pick that voltage?
I also just noticed that you're using two different conventions for crossing wires with no connection. I'd suggest sticking with the dot convention and lose the hump. The humps with connection dots style went out in the 1960's (thankfully).
Also, your posts would be easier to read if you used paragraphs to organize your thoughts.
Those both look like counterfeits to me. Who knows what device they really are.the 2 MOSFETS I went with are these both have Gate voltages of around 2 volts and have Ro of 2mOhm for the N channel and 4mOhms for the P channel. Both I am sure are Chinese knockoffs
You could use a TL431.I may however change that zener for a dedicated voltage reference for more temperature stability.
I have some TL431's in my box of parts that I bought a few months ago. I could try one of those in the circuit I have built up now and see if I can get that voltage closer to my preferred voltage of about 2.9 to 2.8 volts. If they get down to that 2.5 volts or worse lower they tend to lose a lot of capacity. I was given one to test that had discharged to a bit under 2.4 volts for a while and the batter stated 1200mAh and by the time I trickle charged it at low currents it had lost close to 1/2 of that 1200mAh down to a dangerous 680mAh. I advised he not use it.Those both look like counterfeits to me. Who knows what device they really are.
I've bought IRFZ44N and IRF9540N from AliExpress, but I measured threshold voltages and leakage currents on every single device. I also bought IRLZ44N and also did 100% testing for threshold voltage and leakage current. I did leakage current measurements because none of the MOSFETs were packaged correctly (in plastic bags instead of antistatic bags). Since MOSFETs with higher gate capacitances are more tolerant of ESD, I gambled and kept them. I also measured on resistance at 5-6A (largest power supply I had). Now I have a breakout board on a mini-ATX supply.
IRFZ44N should work. The threshold voltage is 2-4V. The device I mentioned was IRLZ44N. That single letter difference is significant. IRLZ44N are logic level devices and threshold voltage is 1-2V.
Note that Vgs(th) for IRFZ44N is the voltage where the device conducts 250uA.
Get used to paying attention to details
IRF9540 is not a reasonable substitution for AO3401. The threshold voltage is -2V to -4V vs -0.5 to -1.3V for AO3401. The device you select needs to be able to conduct the maximum design current (2A) at a Vgs of -2.5V.
Is that from going under 2.5V just once (briefly)? Or was it long term?If they get down to that 2.5 volts or worse lower they tend to lose a lot of capacity. I was given one to test that had discharged to a bit under 2.4 volts for a while and the batter stated 1200mAh and by the time I trickle charged it at low currents it had lost close to 1/2 of that 1200mAh down to a dangerous 680mAh.
When I mentioned needing something like IRLZ44N, you said that you had some. That's not the same as IRFZ44N.I do pay attention to the details
Sadly, the industry has moved on to surface mount devices. I can't find a reasonably priced P channel MOSFET in through hole that would be roughly equivalent to 2N7000. That's why I use AO3400 and AO3401 devices and mount them on SIP adapters.I have no other Ptype MOSFET to choose from I have several Ntypes but only the one Ptype that I have found.
What type of tip do you have now? I use a 700F 1/32" conical tip for almost everything.I probably don't have the right tip on my iron either. I'll have to change it.
You can use the AO3401, but not the AO3400. Use the IRFZ44N. A logic level device isn't required for the N channel MOSFET because there's sufficient headroom for the LM358 with a 9V supply.I ordered the AO3400's and the 3401's I got 10 of each
Where does this information come from? I've been charging my phone and tablet batteries between 40-80/85% for years. I try to keep my Chromebook, Ultrabook, and laptop between 40-80%, but occasionally they discharge to 0%. Sometimes I don't mind them closely enough and charge to 100%.once they get down to about 75% they are on the bad side below 60 and that is entering dangerous territory they could thermal runaway out of nowhere.
