just a question
MisterBill2
Joined Jan 23, 2018
27,514
A sharper picture with some size hint, or a coin for size reference, would hep.
If it was embedded in a patched area then it was simply not removed when a repair or remodel was done. "LaZY WORKMANSHIP" would then be the answer as to why.
Polarbear46
Joined Apr 8, 2024
4
Can you post pictures of the whole thing with better focus?
That seems unlikely. Is your wife an electrical engineer?
thanks Dennis, no she isn't, just finding seeming strange stuff in the house thinks it is bugged from the previous owner. we have little info on the past history of it.
dl324
Joined Mar 30, 2015
18,326
I don't see anything that could be an electronic device. Post some clearer pictures.
Tonyr1084
Joined Sep 24, 2015
9,744
wife seems to think it is some type of electronic device
Are there any wires attached to it? If not - even if it's battery powered, the battery is going to go dead sooner or later. Personally I see nothing to make me think of electronics.
My wife can be somewhat paranoid as well. Every time she screws up a setting on her computer she thinks she's been hacked. Cat'd would be a better definition of what goes on in her office. Our cats walk on everything. Even the printer buttons. She can't understand how or why the settings get changed. I suspect it's cats, not hacks.
MisterBill2
Joined Jan 23, 2018
27,514
The thing does not look like a commercially made bug, and being as it appears to be clear colorless plastic, there are no electronics in it. So the solution is to put it in a bottle full of water so that any invisible electronics can be short circuited. And then put the bottle of water as far from the house on your property as possible. There are ways to defeat even dead bugs tiat don't exist.
Ya’akov
Joined Jan 27, 2019
10,235
Just a suggestion—your wife’s concern doesn’t seem the kind that will be assuaged by eliminating each suspect situation as it arises. With all due respect to her, and with the intention of respectful advice, risking the possibility it is redundant or unwelcome—this sort of concern can be the leading edge of paranoia.
We see many people here with such questions, usually not through a third party. They generally aren’t happy with the answers because they are looking for confirmation, not explanation. In your case, it may not be anywhere near the level we’ve seen—but given the current social climate something triggering a sudden intensification seems very possible.
So, bottom line: please don‘t ignore the possibility of things getting more… acute. It would be easy to deal with each little concern in isolation and miss that it was getting more frequent or more irrational. While you might feel that you can’t say for certain there is nothing going on, I suggest you might want to abandon any attachment to leaving possibilities open on logical grounds and just repeating as often as possible that there is nothing going on.
Take this advice for what it’s worth, which is exactly what you paid for it. A random person from the Internet is not a great source, but you can think about this yourself and maybe research it a bit. It would be easy to step from level ground to join her on the slippery slope if that’s where she is currently standing.
NOTE: I say all this because your house is not bugged by its previous owner. That she would entertain this idea is a bad sign. The world today has plenty of support for wild ideas, it’s very disturbing.
MisterBill2
Joined Jan 23, 2018
27,514
One more comment about any possible bugging is that in the majority of houses listening to the audio from a bug would be horribly boring at best. There might be exceptions, but not many of them.
And in the event of an actual bugged location the simple way to thwart any listening is to constantly have full-spectrum music playing. That will thwart all but the very most sophisticated speech detection systems commonly used to assist analysis of what is spoken.
ALSO, if it is the CIA listening, probably there is a good reason.
