jfet, gate at zero volts
john arclight
Joined Mar 25, 2015
6
Im studying jfets and mosfets at the moment. And Im a little puzzled. This is a paragaph that i was reading for an N channel jfet:
" When no voltage is apllied to the gate, the jfet acts like a resistor. The only limit to channel current is the resistance of the channel, and current flows through the jfet. However, if a negative voltage is applied the gate lead of the jfet, the PN junction is reverse biased. As a result,a depletion region developes in the jfet and opposes the flow of current through the device."
Wouldn't that clearly indicate that the gate at 0 volts acts like a conductor NOT a resistor?
Thank you so much for any input
ericgibbs
Joined Jan 29, 2010
21,567
All conductors have an intrinsic resistance.
jFET's are semiconductors, whose conduction resistance can be modified by applying a Gate voltage.
The FET you describe is a Depletion Mode FET.
38,772
A conductor is simply a substance that conducts electricity.
Its resistance can vary from zero for a superconductor to many megohms for a high resistivity material.
john arclight
Joined Mar 25, 2015
6
Well i understand that all conductors have resistance to current flow....
Alec_t
Joined Sep 17, 2013
15,156
So it's a matter of semantics and intended use. A good conductor is called a conductor; a bad conductor is called a resistor :).
22,111
This is why you have to look at the datasheet very carefully. In the datasheet will be an explicit statement of the range of on resistance for and N-channel FET with 0 volts on the gate with respect to the source. Depending on your expectations that value could either higher or lower than what you expect.
35,136
It is all relative. A conductor is a poor resistor. A resistor is a poor conductor. Or you can have something in between.
Just think of the source-drain channel as a path for charge carrier to flow regardless of whether it is a resistor or conductor.
Read up on the difference between a depletion-mode and enhancement-mode JFET.
http://en.wikipedia.org/wiki/Depletion_and_enhancement_modes
What you are describing is a depletion-mode JFET where the channel allows charge carrier to flow. When the gate is reversed biased the channel is "pinched off" and hence restricts the current flow.
http://en.wikipedia.org/wiki/JFET
