JET Tokamak - 5 seconds of power.
MrSalts
Joined Apr 2, 2020
2,767
One thing I've been wondering - how much energy does it take to refine the Deuterium and Tritium?
Much easier to make tritium than refine it. Plenty of nuclear reactors around the world storing tritium for the 10-half-lives (10x12 years = 120 years) until it can be released into the environment. Deuterium, toss up but much easier to electrolyze the water and use diffusion rate difference and vapor swing absorption techniques to isolate because H2=molecular weight of 2 and DH=3 and D2=4. So, big difference. Rather than trying to separate H2O (18) from DHO (19) from D2O (20 molecular weight).
Interestingly, even though deuterium is non-radioactive, ingesting food or water containing molecules where hydrogen is replaced with deuterium can kill you because chemical reactions are slower (carbon - hydrogen bonds vibrate at a lower frequency when H is replaced with D. (Known as "deuterium isotope effect"). A poor rat was fed nothing but D2O and with each drink, metabolism slowed and soon slipped into a coma and passed.
Ian0
Joined Aug 7, 2020
13,306
That must be the most expensive way ever to kill a rat!
How much deuterium will a fusion reactor require?
38,912
From the ITER website:
a 1000 MW coal-fired power plant requires 2.7 million tonnes of coal per year, a fusion plant of the kind envisioned for the second half of this century will only require 250 kilos of fuel per year, half of it deuterium, half of it tritium.
The tritium will supposedly be produced by a lining of lithium in the wall of the chamber which generates tritium when exposed to the neutrons from the fusion reaction.
bertus
Joined Apr 5, 2008
23,023
Deuterium is often used in NMR measurement techniques as lock solvents.
Many solutions will have deuterium in stead of the hydrogen atoms.
Some examples are : D2O , CDCl3 , DMSO , C6D6 and acetone-d6.
  • Usually the liquid NMR uses deuterium solvent for stabilizing magnet field (lock) and shimming (gradient shimming). If you have to use samples without deuterium solvent, you are not able to lock the field. The magnet field may drift during the accumulation, resulted in broad lines.
Tritium is radio active.
Bertus
Ian0
Joined Aug 7, 2020
13,306
I saw that as well, but it compared a 1GW coal-fired plant with a fusion plant "of the kind envisioned" - were they envisioning a 1GW fusion plant in order to make a valid comparison?
