A temperature controlled pair of NPN transistors. Another old chip.Was this a good idea to build in a heater? It seems any environment that would add heat to the circuit would still add heat to the circuit, more than the heater added? I have seen this built-in heater on voltage references (LM399, LM3999) and thought it was a good idea, but now ... ?
Attached is a page or two of info and an example from the data sheet (to big to include here).
so what do y'all think? Good idea or bad idea?
Some data sheets might just show the two transistors. Added to this is a circuit that acts as a heater. Temperature is controlled by an external resistor. No specs are provided that I could see for how much resistance is suggested for what heat..
The example provided is straight from the data sheet and uses a 709 op amp for a gain of 1,000. Certainly any other op amp could probably be used and frequency limit isn't mentioned. You can't get much out of a 709. It is a forerunner of the 741.
