Cheers lad. When you said pull-down res, did you mount a 10k in the pull down? My original circuit only has one 8.2k res on the not_in node (pin 1 connecting to res and capacitor)I used the pin numbers from your schematic.
Yes. Initially I was going to use a switch to trigger the circuit, but I had a signal generator mounted in the box with the scope, so I used it instead so I didn't have to worry about switch bounce or triggering the scope. I left the resistor because it was a convenient point to connect the signal generator.When you said pull-down res, did you mount a 10k in the pull down?
Would you mind sharing with me the schematic of the connections? I presume you're using 2 resistors?Yes. Initially I was going to use a switch to trigger the circuit, but I had a signal generator mounted in the box with the scope, so I used it instead so I didn't have to worry about switch bounce or triggering the scope. I left the resistor because it was a convenient point to connect the signal generator.
Cheers, I'll retry to mount it on a breadboard todayIt's the same as your schematic with the addition of the pull down resistor:
The device with the bubble on the gate is PMOS.
Tested it out. Worked fine, I probably must have mounted it incorrectly. Thank you all for the help!It's the same as your schematic with the addition of the pull down resistor:
The circuit from @ronsimpson simply replaced the active devices with a resistor. The disadvantages are speed, power dissipation, and pull up strength. CMOS is superior in all regards.Care to explain?
| V | RS485 hardware connection issues. | Microcontrollers | 21 | |
Monostable 555 Trigger release issues | Digital Design | 36 | |
555 Monostable has some output issues. | Digital Design | 8 | |
Monostable 555 Trigger release issues | Digital Design | 4 | |
| S | Help with "non retriggerable monostable" trigger time issues | General Electronics Chat | 4 |
