Hey all!
I have some problems getting LP5036 led driver to work.
Mainly, the most weird thing that is happening is that LEDs are turned on, even if IC is in reset. Meaning, as soon as I apply power, all LEDs turn on and I cannot control them via I2C interface.
It looks like the OUT pins are bridged directly to GND, but that does not make much sense.
Also, I can confirm that I2C interface is working, but I observe no change on the LEDs. If I send command to turn all LEDs off, nothing happens.
The leds I'm using are these: https://si.farnell.com/dialight/598-8d20-107f/led-red-org-240mcd-625nm-0603/dp/3514747
Any help would be greatly appreciated.
Thank you!
Thank you!
