Issues with JDM and other homebrew PIC programmers.
mikejp56
Joined Jun 14, 2015
70
Hi be80be and ErnieM,
Sorry that I haven't responded in a while! I do enjoy building my own stuff, which is why I built the JDM programmer. It works for 12F683 and 12F508, which I had gotten from somebody at work. I have almost finished the USB PicProg from circuits gallery. I will try the 18F2550 in my JDM programmer. If it programs, then great. If not, then that kind of forces the issue to a Pickit 2 or 3. From what I have read, the 2 is the better choice for the bells and whistles that it has? Logic analyzer and ICD count for a lot!
be80be: Does your "clone" work with the pickit 2's logic analyzer and ICD?
Regards,
mikejp56
be80be
Joined Jul 5, 2008
2,395
It works just the same as a real pickit2 just you have to supply 3.3 volts to program a 3.3 volt chip.
that's one of the reasons I made my own I gave my junebug away it's a clone. And then missed having the logic analyzer.
to use and still program with my real pickit2 so I put the 18f2550 on a bread board burned the pickit firmware and didn't have any fet's so I used npn and pnp for them worked great.
You can just add the parts needed to use USB and load the firmware and use the chip as a logic tool too that works fine too i put 1 k on the pins i use.
Oh and people leave out the part that not all pic chips are debugable cheaply some take special headers with chips that you test your code on.
DerStrom8
Joined Feb 20, 2011
2,390
I must have misunderstood, I thought Microchip removed the debugger functionality from the PK3 in order to push their separate ICD product. If I'm wrong, then great!
jpanhalt
Joined Jan 18, 2008
11,087
@DerStrom8
These comments apply specifically to the 16F1829 using MPLab 8.92:
Although PK2 and PK3 will often work interchangeably, with the PK2 offering a logic analyzer, using stock Microchip software, the PK2 is not listed for programming or debugging newer chips:
As always, it is best to check the manuals for a specific device, chip, and tools. I have read that there are aftermarket add-ons for the PK2 that expand the range of chips it can handle.
John
DerStrom8
Joined Feb 20, 2011
2,390
@DerStrom8
John
This was very informative, thank you John!
MaxHeadRoom
Joined Jul 18, 2013
30,808
I had to get the Pickit3 for the latest 18F23K22 and up etc, the device chart shows essentially the same posted by John. But it just shows the ICD 2/3 which are separate modules, the MPLAB also has a debugger function using Pickit2/3 itself, depending on compatible chips for each.
Max.
mikejp56
Joined Jun 14, 2015
70
Hi Guys,
Sorry that I have been away for a few weeks. I ordered several PICs and other parts from Digikey, and I have successfully programmed and verified an 18F2550 with the hex code for the USB PICPROG from the circuitsgallery website, using my homebuilt JDM programmer and WinPIC800 software. I will build the USB PICPROG programmer next, and update this thread when I have some results to report.
Regards,
mike
atferrari
Joined Jan 6, 2004
5,028
Maybe eight (?) years ago prior buying Picstart Plus, I built Fred Eady's Pic Replicator. Two years ago, when the Plus died, it came back into service with little problems. Microchip (AZ), when asked about the failure, replaced it with no questions from their side and in no time.
To be fair with them, given their attitude, I sent my failed one to USA. I paid Fed Ex more than if I decided to buy a new one here.:p
I doubt I would build any new programmer in the near future. Some time in the past, DIY programmers seemed to me, kind of a subset in the religious wars going on. Now it it seems (to me) more a nostalgic activity. I prefer to explore new spaces (like designing a PID controller with op amps :p :D :p).
mikejp56
Joined Jun 14, 2015
70
Hi be80be,
OK,so I finished building the USBPICProg from the circuitsgallery website. When plugged into the USB port, one of the LED flashes and nothing happens. I get an error message to reinstall the driver and/or the software. I get this error message on 2 different PCs. I am convinced that my hardware is properly built; using an ohmmeter and scope to verify functions. So I am convinced that this is a software/firmware issue.
I am willing to build your circuit as shown in post #18 and try it out. Can you post the hex file that gets put into the '2550 please?
Thanks for your help, and I will keep you informed.
Regards,
mike
mikejp56
Joined Jun 14, 2015
70
Hi be80be,
Regards,
mike
Hi be80be,
Are you still out there? I am interested in building your programmer; can you post the code for the 18F2550, or do you want to do a PM?
Regards,
mike
be80be
Joined Jul 5, 2008
2,395
I'm here You need this it installs the program software and the firmware is with it.The first link doesn't have net framework A you can use it if you have that installed
the second one is the whole ball of wax with net framework A
http://ww1.microchip.com/downloads/en/DeviceDoc/PICkit 2 v2.61.00 Setup A.zip
http://ww1.microchip.com/downloads/en/DeviceDoc/PICkit 2 v2.61.00 Setup dotNET A.zip
Attached is the firmware for the programmer. And I know it works. Only problem I see is getting it in the 18f2550 I used a real pickit2 to program it with it. I tried maybe 20 jdm to load it they never worked. I made a idc2 it worked on serial using the
PIC16F876 http://smisioto.no-ip.org/elettronica/icd2_clone/icd2_clone-en.htm
mikejp56
Joined Jun 14, 2015
70
Hi be80be,
Much thanks for the FW. What is the value of the inductor in the collector of Q2? I will build this in the next few weeks or so and keep the thread posted.
Regards,
mike
dannyf
Joined Sep 13, 2015
2,197
According to microchip it is 680uH.
That's exactly what I meant: Microchip used too big of a value. I would top it out at 110uh or 220uh - there is very little current on Vpp, even if MCLR is pulled low.
