Issues with CD40110B
matgube
Joined Nov 16, 2023
30
Hi all,
Foreword: I'm (really) new to electronics, this is my first project.
I'm trying to get a simple counter working with a CD40110B + 7 segment led. After smoking some components I got to a setup that seems to work BUT sometimes it skips a number, e.g. from 4 to 6. Both up or down.
I tried replacing the buttons and the counter, but no luck. The 5V supply seems stable, it's rated for 30W.
I'm using this schematic with additional 330 Ohm resistors inline each segment input.
Buttons: Adafruit buttons
Digit: Wurth WL-T7DS 7 Segments Display THT Single Digit T7DS056SC
Counter: CD40110B
Any idea of what the issue could be?
Matt
k1ng 1337
Joined Sep 11, 2020
1,038
Try rebuilding the circuit on another breadboard with different jumpers. If not that, its probably due to switch bouncing. Try out a few debounce circuits.
Once you did that and the problem still is a pattern that never changes like always skipping #5, the IC is probably cooked.
matgube
Joined Nov 16, 2023
30
Apologies, I forgot to mention I switched the breadboard too. The number skipped is random.
I'll try with the debouncing circuits, thanks.
Matt
Ya’akov
Joined Jan 27, 2019
10,313
Welcome to AAC.
Your circuit is almost certainly suffering from switch bounce. This is very normal and is a mechanical phenomenon. The switch will sometimes close, the bounce, and close again.
The general solution is to select an appropriate capacitor to act as a low pass filter. Since the capacitor will charge up and takes time to discharge, transient off-on pulses will not be seen by the IC.
The capacitor (and a discharge resistor) have to be chosen for the correct RC time constant. For the circuit. There are many tutorials online for debouncing. Read a little and come back with any questions,
35,228
Read up on what is switch bounce and ways to overcome it.
There are basically four techniques that can be used:
1) Simple RC filtering
2) RC filtering with Schmitt trigger gates, also with NAND gates
3) SPDT pushbutton with S-R flip-flop circuit
4) Software
Since your application is all hardware, you can ignore (4).
Solution (1) in its simplest form
One of many versions of Solution (2)
Solution (3)
matgube
Joined Nov 16, 2023
30
Hello, quick update. I got some caps but no matter what I tried to do it did not work. If anything, things got worse with a cap.
I replaced the IC once more, used a button scavenged from somewhere else but no luck.
At this point the only thing I can think of is either the breadboard or the power supply. I'm using a phone recharger-style adjustable supply, maybe that's the issue? I ordered a proper one and we'll see.
matgube
Joined Nov 16, 2023
30
Btw, until now I went with trial and error to pick a cap value.
I know the high level theory, but how can I assess the time constant I need to calculate RC?
matgube
Joined Nov 16, 2023
30
The one in the first post, but with 330Ohm resistors on each segment line.
Where should I take the time constant from, the datasheet of the counter?
Thanks!
35,228
Thanks!
R is the value of your pullup resistor.
C is the value of the capacitor.
Try,
R = 100kΩ
C = 1μF
You need to show your circuit, even a photo of a hand drawned one.
Alec_t
Joined Sep 17, 2013
15,158
Try connecting (using short wires) a decoupling capacitor (~1-10 uF) between the + and - supply pins of the IC, as close to the IC as possible.
matgube
Joined Nov 16, 2023
30
So... at the end it seems that this configuration is quite stable, am I doing something wrong? Does it mean my power supply is not great?
