Issue regarding PWM output on Microchips PIC10F322
morethegr8
Joined Feb 14, 2011
31
Oh and just in case anyone is looking for a working example in the future:
Rich (BB code):
/*  38khz pwm on RA1 with 50% duty cycle.
   Timer 2 is is 52 decimal
   Prescaler is 1
   Duty cycle value is 106 decimal                 */
#include    <htc.h>
#define _XTAL_FREQ 8000000
//__CONFIG (FOSC_INTOSC & BOREN_OFF &  WDTE_OFF & PWRTE_OFF & MCLRE_OFF & CP_OFF & LVP_OFF & LPBOR_OFF & BORV_HI & WRT_OFF);
#pragma config FOSC = INTOSC    // Oscillator Selection bits (INTOSC oscillator: CLKIN function disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // MCLR Pin Function Select bit (MCLR pin function is digital input, MCLR internally tied to VDD)
#pragma config CP = OFF         // Code Protection bit (Program memory code protection is disabled)
#pragma config LVP = ON         // Low-Voltage Programming Enable (Low-voltage programming enabled)
#pragma config LPBOR = OFF      // Brown-out Reset Selection bits (BOR disabled)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
void InitPWM();
void main()
    PORTA = 0b00000000;
    TRISA = 0b00000000;
    ANSELA = 0b00000000;
    CLC1CON = 0b00000000;
    CWG1CON0 = 0b00000000;
     InitPWM();
      while(1)
void InitPWM()
    PWM2CON = 0b00000000;   // Clear PWM1CON
    PR2   = 0b00110100;     // Configure the Timer2 period - decimal 52
    PWM2CON = 0b11000000;   //Enable PWM Module, Module Output
    PWM2DCH = 0b00000000;   // Clear duty cycle registers
    PWM2DCL = 0b00000000;
    TMR2IF = 0;             //Clear the timer 2 interrupt flag
    T2CON = 0b00000000;     //Set prescaler to 1
    TMR2ON = 1;             //Enable timer 2
    TRISA=0b00000000; =        //Enable the pwm pin output
    //Set duty cycle to 106
    PWM2DCH = 0b00011010;
    PWM2DCL = 0b10000000;
    return;
I have use code from Mr Setanta to generate PWM on PIC10F322.
But it seems this code is not working.. !
I have read the datasheet and followed the same process as described but still no outcome.
Is this code working?? Do i have to set anymore Registers ? BIts ??
Anyone with working code for PIC10F322.. Please help.
jayanthd
Joined Jul 4, 2015
945
Change
Code:
to
Code:
#pragma config LVP = OFF         // Low-Voltage Programming Enable (Low-voltage programming enabled)
AlbertHall
Joined Jun 4, 2014
12,653
Change
Code:
to
Code:
Yes, if TS is not using low voltage programming then it should be turned off.
Interestingly, line 12 says LVP_OFF
