Sorry I am a novice when it comes to the lingo so I should connect S1 to the grounding lug on the input side and connect S2 to the ground lug on the output side? Note the ground wire from the generator is also connected to the input lug.Your shield wires provide several options. For noise shielding you connect it to GROUND along with chassis of the transformer itself.
DO NOT CONNECT IT TO THE GENERATOR WIRES
This will shield the output from noise coupled between windings by capacitance. This is usually only needed where large servo motors are used and lots of high freq trash is on the powerlines
The inductance of the transformer itself will benefit you by acting as a low pass filter to the line freq harmonics of the generator.
I have something similar to this and I fully understand that I need to turn off the main before backfeeding the house.Just saw this thread.
There's a company that will modify a panel (the one that goes over your breakers) for you to have interlocked breakers. https://www.interlockkit.com/ You can't have the generator feed and utility power on at the same time. It's an approved mod. A mechanical interlock.
To use the generator as a whole house generator, you have to break the neutral/ground bond at the generator. You can't have neutral and ground bonded in two places.
So, standalone and whole house use different wiring schemes. Now, figure out a way to do that safely.
Thank you for your reply!The easy way to deal with them is to get a whiteout pen and cover up S1 and S2 on the circuit diagram
You really do not need to worry about them at all. They are not important and just a noise blocking device.
But it would be a good idea to get your installation checked by someone who knows what they are doing. Here in Oz, it is actually illegal to touch your house wiring unless you have a current Electrician's certificate.
If you get it wrong you could burn your house down or electrocute someone. Please be careful!
It has nothing to do with S1 and S2, but it does have to do with the noise and ground loops.The setup I have also only has the neutral and ground bonded at the main panel and they are separated at the sub panel. I just don't get this wiring diagram and what on earth to do with the S1 and S2
