Isolation derating of flyback transformer
DivadLarsen
Joined Mar 7, 2010
I'm designing a small flyback transformer (~30W), single output. The issue of my design is the input common mode voltage, that's specified as "up to 1500V indefinitely".
Now, I can easily get 1500V rated transformers, but the rating is usually 1500V for 1 second or 1 minute.
Alternatively I can get 4kV isolation for 1 second/minute, but this may be overkill.
What I am curious about is how I calculate/derate to the max. isolation voltage for indefinite usage (or just 1 day, if easier).
I've been referred to the IEC 61558-2 standard, but like everybody else I don't want to buy it, if it doesn't answer my question (standards rarely do) :)
Does anyone have experience with this type of issue?
Regards!
Ian0
Joined Aug 7, 2020
13,317
Your local public library will have a copy of the standard.
Note: check whether the voltages are peak or rms. It makes 41% difference!
Does your transformer really need to withstand 1500V indefinitely? Where is it being used?
DivadLarsen
Joined Mar 7, 2010
Hi Ian,
thanks for your reply; I will definitely check out the library! I haven't had much luck in finding Standards there in the past, but it absolutely worth a shot!
The PSU is placed differentially somewhere on a string of solar panels, with a potential accumulated DC voltage of 1500V - hence the requirement.
I do realize the actual requirement may "only" be up to 14 hours per day - but that seems very close to indefinite in my experience :)
Regards!
