Isolating oscilloscope versus isolating test circuit
IBCNU
Joined Jul 19, 2018
6
Not quite how I'd describe it. See if this makes sense:
A normal isolation transformer *should* not have any connection between the "ground" pins on input and output. In other words, it *should* break the ground path completely.
It sounds like, in your case, the isolation transformer did not break the ground path on the scope as expected. Although perhaps another possibility is that the transformer was set properly but something else completed the ground path. For example, maybe the scope chassis is metal and was resting on a grounded metal table or countertop, which provided a ground path. In any case, it sounds like your scope had its chassis grounded when you expected it not to be.
As for why isolating the rectifier circuit worked, even though the transformer may not be isolating the way we want it to, there are several factors here:
1) As @IBCNU stated above, in North American mains power, the neutral is tied to earth ground at the breaker panel, so electrically they're basically the same (there are important safety reasons to treat them differently and follow all applicable electrical codes, but for the purposes of the following analysis, they're the same.)
2) Your rectifier circuit used a two-prong plug, meaning it utilizes 120V Line and Neutral, but no third connection for Earth Ground.
3) Because of the Earth Ground-Neutral connection in item 1, your rectifier circuit is still ground referenced, even when it's only connected to Line and Neutral.
4) Because the rectifier circuit is ground-referenced through the neutral on the input side, you can see in @CharlesWMcDonald's simulation above that the rectified output "rides" the AC waveform. In other words, the difference between the two output terminals is rectified DC, but both output terminals still carry a high AC voltage relative to Earth Ground.
5) Assume for the sake of analysis that *your* isolation transformer is providing transformer isolation for Line and Neutral, but is providing a direct (not isolated) connection for Earth Ground.
6) For all practical purposes in terms of safety, the signal ground, the Earth Ground, and any exposed metal frame on your scope are all equally grounded.
When you add all these facts together, this is what you get:
In the first scenario, when you tried to isolate your scope, it was still grounded. When you connected your signal ground to the rectifier output, you actually connected AC mains (on the rectifier output) directly to Earth Ground (on the scope "signal" ground clip.)
In the second scenario, isolating the rectifier circuit, the transformer isolation worked, because you only have a two prong plug. The rectifier circuit was then "floating" with no DC connection to Earth Ground. When you connected the scope probes to it, that grounded the negative side of the output to Earth Ground, providing a stable reference against which to measure the positive output.
Sorry I wrote quite a lot there. Hopefully this makes sense. Let me know if you have any questions.
IBCNU
Joined Jul 19, 2018
6
IBCNU
Joined Jul 19, 2018
6
Something else I thought of. When I got my isolation transformer I had to remove the green earth grounds wires from the female outlets but left the earth grounds on the transformer case BUT!! I replaced the female outlet the female outlet with a hospital grade outlet that keeps the screw that holds it from shorting to the case in the USA they are orange and all the terminals are isolated. Perhaps this was a problem in the OP. Just lucky I checked! it's a name brand isolation transformer also. Not sure how they can call it an Isolation transformer and still reference ground.
28,183
The only place
to reasonably use an isolation transformer is indeed to isolate the circuit that you are working on. There are instances where an oscilloscope does need to be isolated but those are for noise voltages that are present where there should be solid grounds. But that is not applicable in this instance. Isolation of a circuit with an effective isolation transformer allows whatever point the scope common (ground) clip is attached to the ability to serve as the reference point for the signal being observed. Without adequate isolation that will not work. THAT is why you should be using an isolation transformer when using a scope to examine wave forms. The fact that it also tends to reduce the shock hazard is a happy side effect in this case. BUT to keep the benefit of that isolation transforemer you need to avoid connecting the "green wire" safety ground to your isolated circuit.
A problem does exist that some engineers will indeed float a whole oscilloscope package off ground at some times. Just because they can get away with doing it does not make it safe or smart. If done exactly right it can work, but it will not be safe nor even sort of safe.
BR-549
Joined Sep 22, 2013
4,928
The term isolation has several contexts. In a hospital.....isolation transformers are for electrical noise. Not voltage. It's completely different.
Sometimes you need to isolate the power source.
Other times you need to isolate the DUT. device under test.
Other times you need to isolate the measuring equipment.
It depends on ALL the details.
MAGA
