Is this PCB mounted component a fuse?
DickCappels
Joined Aug 21, 2008
6,369
A friend sent this to me. Assembly part is on the board that is inside a battery operated appliance.
(Above) The board
(Above) The strange component next to R1.
Does the strange component next to R1 with what looks like a hole in it a look like a fuse?
Thank you in advance.
jpanhalt
Joined Jan 18, 2008
9,338
You say "component." Does that mean it looks like it can be removed?
On the top, it appears to be completely surrounded by solder mask. What does the bottom show? Could it be a Test Point that is connected by an untented via to whatever is on the bottom?
The absence of any silkscreen might weigh against it being that.
DickCappels
Joined Aug 21, 2008
6,369
I'm pretty sure it is soldered into place.
Can't tell much from the back of the board.
Thank you for those ideas. Agreed, if it doesn't have a designator on the silkscreen that's a suspicion.
I will ask my friend to probe around with an ohmmeter.
jpanhalt
Joined Jan 18, 2008
9,338
I couldn't detect any traces around the top. Considering how small things are getting, it could be a gas sensor (the hole) in a BGA package. But there would have to be at least 2 and probably 3 connections on the bottom. Does that hole goes clear through the board? (I can't tell from that picture.)
