is this mosfet faulty ? mdf4n65b
disturbed123
Joined Jun 11, 2020
122
the question about resistance was principal and comes from manual for repairing lcd monitors. that`s why i created another thread. i will read everything in this thread later...
bertus
Joined Apr 5, 2008
23,006
Inrush limiting will be NTC, not PTC.
You are right:
NTC
When power is applied to a circuit with an NTC, the NTC’s resistance starts off high.
After the inrush current has passed and the converter is running at steady state, the NTC heats up and its resistance drops.
NTC’s limit the inrush current only when they are cold.
When power is turned off and quickly on again, the NTC does not have time to cool down and will not limit the inrush current.
For inrush current limiting, the NTC must be connected in series with the load circuit.
Several limiters can also be connected in series for higher damping.
Inrush current limiters must not be connected in parallel.
https://forum.digikey.com/t/inrush-current/679
Bertus
