Is this even legal?
xox
Joined Sep 8, 2017
936
I bought several 100 F capacitors via eBay. They tested out ok. Now, what practical use is there for a 100 F capacitor?
Low voltage energy storage maybe? Connect a set of those to a solar cell and charging circuit, then use that to power an Arduino for example...
Ian0
Joined Aug 7, 2020
13,271
Even English to English can be problematic. I worked with a programmer newly arrived in the U.S. from Australia. He went up to the female admin and asked is she had any rubbers, and was totally at a loss why she turned bright red.
rubber (Australia): eraser
rubber (U.S.): condom
And then there was was the Brit who made a date with an American woman and told her he would “knock her up at seven.” But maybe that one is apocryphal.
Bob
A date that early in the morning?
And that first drawing for your new project (the one for which you need the rubber to correct it) would be done on the back of a fag packet -at least it would have been before smoking became less popular.
MrSalts
Joined Apr 2, 2020
2,767
You put 5 in series and you get a 13.5v capacitor with 100F capacitance. Full loaded, it should crank a car's starter motor for 1.5 (worst case) to more than 10 seconds (for a small car w/1.8L engine) - assuming you stop cranking at 10v.
Ian0
Joined Aug 7, 2020
13,271
It might if the ESR is low enough, but those pins might get a bit warm.
MrSalts
Joined Apr 2, 2020
2,767
Yeah it was just to show how much energy is stored in 100F at 13v. About 4000W for 1 second (4000 joules). More if you can do significant work as it discharges all the way to zero. About 9000J - if my math is right.
Ian0
Joined Aug 7, 2020
13,271
I’ve seen two types of these super capacitors. On type seems to have ESR of several ohms, and could only really be used to keep logic or memory alive, and another type appears to be capable of some serious power delivery.
luvv
Joined May 26, 2011
191
I replaced some dead ni-cads in a crank style emergency flashlight with w/ super caps and that's been years ago. Charges up to a usable state much faster and given the very infrequent use,doubt I'll ever run up against the charge cycle lifespan in my lifespan.
