Is this calculated value correct? What does the max. distance mean?
Papabravo
Joined Feb 24, 2006
22,115
The max distance refers to how far a line-of sight signal at a given frequency is expected to propagate before the attenuation reaches a level where it cannot be demodulated to recover any useful information.
Papabravo
Joined Feb 24, 2006
22,115
Can you please explain through a diagram? I am not getting it.
You have the diagram in your original post. It shows a satellite above a ground station at an altitude of 160 km which means it is in a low Earth orbit. The limits to line-of-sight transmission occur because of the curvature of the Earth. The other limitations have to do with transmitter power, receiver sensitivity, and signal attenuation along a path. The signal level of -176 dBm is understood to be the level where a signal drops below the noise floor rendering it undetectable. The max distance occurs along the path from the satellite to the horizon from an altitude of 160 km. The signal may or may not reach the horizon if it is low power or the receiver lacks sufficient sensitivity.
Solanum Asteridion
Joined Sep 5, 2023
36
So that means that if the satellite is in the LOS of the ground station, they will start communicating?
Solanum Asteridion
Joined Sep 5, 2023
36
sure thank you..
I first calculate the wavelength (lambda) using speed of light / frequency.
Then received power is calculated by Transmitted Power (in dBm) + Transmitter Gain (in dBi) + Receiver Gain (in dBi) - 20 * log10(Wavelength / (4 * π * Distance in meters))
Then it checks if received_power_dbm >= receiver_sensitivity_dbm, if so, the signal will be received by the ground station?
Finally, Maximum Distance (in kms) = ((Wavelength / (4 * π)) * 10^((Transmitted Power in dBm - Receiver Sensitivity in dBm + Transmitter Gain in dBi + Receiver Gain in dBi) / 20))/1000
Papabravo
Joined Feb 24, 2006
22,115
sure thank you..
Something does not make sense here. There should be no problem with transmission and reception between the ground station and the satellite overhead. I thought the problem was about transmission and reception from the satellite to a station at the periphery of the circular area of the sphere above the horizon from the satellite's point of view. So idk what you are talking about.
Solanum Asteridion
Joined Sep 5, 2023
36
When the satellite is in the red colored part, will I be able to communicate with it? That is my question. Also what is the maximum distance that the satellite can be placed into orbit so that it will still be able to communicate with the ground station while it is in the red group?
