Switch is out of the wall. Just wires hanging.Wired to the SW or disconnected?
Leakage might be the case. I just know the wiring is very wacky. There is at least 6 items hanging off a single breaker. This ceiling fan, ceiling lights, multiple outlets...In the off position there is only continuity between A and C.
In the on position there is continuity between A and B.
I have 1-ways on hand. So just pop it in between A and C and see if there is smoke?As far as I can see an ordinary 1 way SW , you could tape the 3rd conductor, or going the 3 way SW should work also.
Do you have them on hand to test it?
Max.
Yes, it is a switch for a '3 way' circuit. (Common A, normally open B and normally closed C) Being used now as a single circuit.In the off position there is only continuity between A and C.
Now that was truly classic!Prior to the invention of dirt, most electrical items did not need to be enclosed.
For those who care... It was just the CFL bulb went bad. Whew.Drat. I went to turn on the kitchen light and -- nothing happened. Now I have to wade into the lamp-switch-wiring swamp myself.![]()
I had a challenging service call with a situation like that a few years back. A lady complained that the switch failed and so she replaced it and the light still did not work. After several minutes of checking it became obvious that both bulbs in the fixture had failed. She was not easy to convince, but when I put in one new bulb and it worked there was no alternative but to agree.For those who care... It was just the CFL bulb went bad. Whew.
