MaxHeadRoom
- Joined Jul 18, 2013
- 30,885
Yes OK electrically, but it is not observing current safety wiring regulations.But as I noted, it's not likely to make a difference which way you connect it.
True.Yes OK electrically, but it is not observing current safety wiring regulations.
It DOES matter .I'm of the opinion that it doesn't matter. If it did matter then they would have used cable that color codes the other two conductors. If the wire has no colors (except for ground) then how could even they wire it up correctly?
The people assembling the unit would have been staring at exactly what you are and there's no way they could distinguish one side from the other (unless they used a ohm meter but that sounds far more risky than just using color coded wires.
I suspect the unit switches both conductors on/off not just one.
Since there is no ribbing on the exterior of the cable I've seen printed or inked markings on the Neutral or Negative leads. I've seen all black 2 conductor with white dash marks on one of the two conductors indicating (should the home holbiest need to know) typically either the negative or the neutral. I've also seen printing such as in the picture to POSSIBLY (I said "POSSIBLY"!) the neutral. I'm hoping others will confirm or debunk this statement, but if I had no choice but to proceed I'd use the printed side as the neutral.Connect the cable with the writing on the side to LINE (to the narrow prong, copper color).
Connect N to the wide prong, labeled W in the plug diagram, the screw is usually silver colored.
"Should" - yes, it matters. For sure it matters. Even if: (next quote)I would say it SHOULD matter
I've been shocked MANY times because of an improperly wired socket or plug. I lived in a house with old Knob & Tube wiring. The home owner thought AC meant it didn't matter. He half upgraded some of the wiring (poorly done at that) which before I knew about K&T wiring in the walls he inadvertently mis-wired a plug or a light socket. This is why you turn off the breaker - or remove the fuse as in the case of K&T wiring - before you THINK something is de-energized. A mis-wired socket is no reason to think it doesn't matter.for the fuse reason, but you never know how is the wall socket wired.. so it... doesn't ?!
I'd agree IF we knew there was a fuse and the switch was single pole. He claims he cannot access the insides so it might not even have a fuse.It DOES matter .
As said earlier, the fuse must be on the LINE and go before the switch, among other safety concerns.
Would you base your safety and the safety of your family on that statement?it might not
No, but then there are few things I would!Would you base your safety and the safety of your family on that statement?
I'd open the unit up and replace the cable with color coded, better cable I think, resolve the matter and be done.I understand you Tonyr completely.
My first job was electric installations, and I found out first hand (my hand that is) that there are talents who were wiring the neutral to the switch and the hot directly to the ligthbulb, so you have 220V above your head even if you turned off the switch.
My point was... according to electrical standards it MUST matter which is neutral or hot. Purely for the functioning of the device - probably not.
100% agree. Better solution than putting a "Fix-It" plug on the end of a cable when you're unsure what goes where. Even if you're 90% sure which is neutral and 100% sure which is ground. While you just might get away with it it's not worth the risk. Especially if this is in a rental unit. Someone gets a shock - gets mad - gets an attorney - gets rich just because of a stupid plug that accidentally got wired wrong?! Being the smart AND CROOKED kind of guy I might be - I would unplug the unit, change the wiring, make the ground poor, put it all back together then get a shock. Call the cops so they can then see there's a potential for injury, get documentation on it - then sue you. OK, that's not who I am. But - - - !I'd open the unit up and replace the cable with color coded, better cable I think, resolve the matter and be done.
But this isn't a plugged in unit - it's a unit whose plug has been chopped off. The TS wants to replace the plug with a Fix-It 3 pronged 120VAC plug. The chances of wiring the plug wrong is very real. Swap the neutral and hot could lead to a potential shock IF the ground connection is not properly made.If nobody is going to be poking their hands inside the wiring of the window AC appliance while it is plugged in to a live source, AND if the green-wire safety connection is good from that AC unit's frame to a solid GROUND, then there does not exist a hazard, except in the minds of some folks.
