Is there a substitute for (2)OA99 germanium diodes?
jeromach
Joined Sep 29, 2013
9
I'm repairing a Technics SA-828 receiver which is in need of 2 pieces of 2OA99 germanium diodes.
The only present subsitute I come across is an NTE device, not my first choice of brand.
Can such a diode be substituted by a schottlkey diode or are there any germanium diodes still produced?
jeromach
Joined Sep 29, 2013
9
Thanks E.
Unfortunately, no shipping to Europe.
I did some more checking, a substitute to the 1N34A and the 1N60 would be the CDSH270 (obsolete) and that would substitute to the BAT41. The latter is not a germanium diode, but would it not just do the job as well?
jeromach
Joined Sep 29, 2013
9
Netherlands, I could buy from England, no problem.
Still, after having done even some more research, I found out that the difference between OA99 and 2OA99 seems to be that the latter is a matched set of 2 OA99's.
Interesting. What would be the things to check when matching, forward voltage drop? I never noticed very large difference in between diodes of the same model when it comes to this.
ericgibbs
Joined Jan 29, 2010
21,567
hi,
For a Receiver, I would ensure that switching speed and inter electrode capacitance is similar to the original.
Most general purpose Ge diodes have the same forward voltage drop.
jeromach
Joined Sep 29, 2013
9
I checked some germanium diodes I had in my parts box, they indeed individually differ a lot on voltage drop! I didn't know that, regular silicon diodes are much more constant.
As for the SA-828, the 2OA99's are part of the power amp board, so no radio function here. But they indeed are present in pairs and now I know they are matched I need to look into that when replacing them.
I'll probably order a bunch of 1N34A's and see if I can match them.
Thanks for the input so far!
RichardO
Joined May 4, 2013
2,270
The major differences between a germanium diode and a Schottky diode will probably be breakdown voltage and leakage current.
I suspect that neither of these are a problem.
If you post the schematic you will get better answers.
