That voltage doesn't matter. It can be anything from 0 V up to the breakdown Vds of the FETs. The gate drive will be supplied from the 12~15V on the other side of the diode, and that will determine the Vgs of the high-side FET. The drain supply has no effect on this. I have personally designed and built H-bridges with the Vgg gate drive supply independent of the Vdd drain supply. The Vdd can be anything at all, so long as the FETs breakdown is not surpassed.What is the voltage at the top of the H? The supply should be 8 - 10 volts higher that this.
Regards
