A strange H bridge circuit, How does the Nmosfet drived?
vincentcheng
Joined Jul 10, 2024
Hi, everyone. I have a schametic that quite confusing me. as far as I know, one should apply the Vgs voltage about 12V to drive the NMOSFET,
the BUS- is the battering minus and it is the primary side "gnd" in a flyback converter to make 12V, where the GND is pull out from secondary, there is no electrical connection for them both.
In this case, How can the MosFET be drive? it seems the S terminal is floating?
vincentcheng
Joined Jul 10, 2024
There is not enough diagram shown to sort this out, where does INVPWM+G come from?
Hi, Sensacell , thank you for your answer. here is more information about the driving signal.
it seems they should be connected externally by a wire. some times to connect a test equipment in series? wire.PNGwire2.PNGdrvie.PNG
Orson_Cart
Joined Jan 1, 2020
110
you need to research: " bootstrapped gate drive power supply " and chips like the IR2113 for high and low side driving of gates - the iC has an internal level shift. The data sheet for these GD IC's does a pretty good job of explaining all.
28,600
Since no connection to the mosfet source side is shown, the truth is that the circuit shown will not function because there is no mosfet gate drive. . So what you see is not a working design as it is presented.
Much like a story with words left out.
If the connections not shown are added then the circuit might work.
So your question is indeed proper, because AS SHOWN the circuit does not work. Wishing it would work does not help.
