I think his question was around S3.Is that supposed to be a barrel connector? A power port? Looks to me like pin 1 is the center pin of a barrel connector. Pins 2 & 3 open when the mating connector is plugged in.
What is the barrel jack used for? I hope not power.
That is for power. The unswitched version works correctly.What is the barrel jack used for? I hope not power.
You still haven't described what you want the switch to do. It appears that you're using an SPDT switch when SPST would have been sufficient. If that's the case, you could have left the NC terminal unconnected.Updated. I took 3 to 1, but not sure which pin is voltage.
To connect power to circuit.You still haven't described what you want the switch to do.
Not sure I can but will give it a try.Your schematics will look "better" if you ditch the colors and grid.
Yes, headers. Modules with other headers connect to them.I assume that the DZ254* components are headers. What connects to them?
What happens if you connect power to a header and have the switch closed? What happens if you connect power from all three connections? Why do you need so many power connections?To connect power to circuit.
Printing to PDF in black and white will ditch the distracting colors. Nothing screams amateur more than colored schematics.Not sure I can but will give it a try.
Ok, resolved except for your schematic advice: are you saying to not include component information. Without them I make it harder for the reader to find the info?You still haven't described what you want the switch to do. It appears that you're using an SPDT switch when SPST would have been sufficient. If that's the case, you could have left the NC terminal unconnected.
Schematics are easier to read if you don't have text placed over wires, components, or other text. I assume that the DZ254* components are headers. What connects to them?
You didn't need to connect pins 2 and 3 of the power jack. When you connect a supply to the jack, pin 2 will be connected to the outside of the female plug.
What should I be using?BTW, you used an earth GND symbol, is the common actually at earth potential.?
