is-quantum-communication-faster-than-the-speed-of-light?
WBahn
Joined Mar 31, 2012
33,357
Although I haven't read Einstein's 1905 paper, "On the Electrodynamics of Moving Bodies", in the original German, I have read it in the English translation and he very much did hypothesize that the speed of light was a constant -- that was, in fact, the second of two postulates upon which he built his special theory of relativity. His two postulates were:
1) The laws of physics are the same in all inertial reference frames (first put forth by Galileo).
2) The speed of light in a vacuum is the same for all observers.
When you think about it, this is the proper way to go about it. You want as simple a set of postulates as you can use and then come up with testable conclusions that rely on the validity of those postulates. If the tests fail. then at least one of the postulates is not correct. With the first postulate being a very well established one and the second being one that was very much up for debate, if the tests fail, it is overwhelmingly likely that it is the second postulate that is invalid.
Postulating that there is no aether would have made testing difficult because, if the test pass, people could try to argue that it doesn't support the postulate, but rather just requires a better understanding of the aether. Similarly, if the tests fail, it doesn't really prove that an aether exists, since there might be some other explanation. The underlying problem is that the aether, if it did exist, was not tightly characterized as far as what it's properties could and couldn't be.
But a postulate such as the speed of light in a vacuum being the same for all observers is much more cut an dried. It doesn't matter why it is the same, only that it is. The tests can then probe whether or not it is by looking at the predictions that result from that postulate relative to what would be expected if that postulate was invalid.
cmartinez
Joined Jan 17, 2007
8,896
Would you say that stating that the speed of causality is what actually determines what the speed of light is an even more fundamental postulate?
WBahn
Joined Mar 31, 2012
33,357
I never got that deep into the modern physics to grasp all of the nuances, but the basic problem still remains -- if you are putting forward a testable theory, then it has to be testable. So your theory would have to show that the speed of light is determined by the speed of causality and not anything else -- that it is a consequence of the postulate. Assuming you do that, what tests would you construct to test it?
Futurist
Joined Apr 8, 2025
952
2. follows from 1. because the speed of light is defined by Maxwell's field equations, it is a law of physics which must be the same for all inertial observers. Nothing special about the speed of light that warrants it being called out, all laws not just Maxwell's, are the same for inertial observers.
Yes Einstein did state the constancy as a written postulate but its redundant, because it's implied by the principle of relativity, he could just as easily postulate that there is no aether.
The reason I said what I did, is that all too often discussions about (special) relativity become fixated on "the speed of light" in ways that obfuscate what's going on. Thus we get stuff "how can we be sure that nothing can go faster than the speed of light" and so on. By making the speed of light some central tenet it masks a deeper reality which is that all observers (inertial) will always see the same laws in action.
That is the central postulate here, the belief that natural phenomena conform to the same laws even though observers might observe the same events with different measurements. Like with electric and magnetic fields, an observer travelling with an electric current sees no current and hence sees no magnetic field yet his observations are still described by Maxwell's laws.
Once we accept this, questions like "how can we be sure that nothing can go faster than the speed of light" become "how can we be sure that all observers always observe the same laws in action", which kind of puts the question in a very different light.
WBahn
Joined Mar 31, 2012
33,357
The speed of light as determined by Maxwell's equations does not rule out the possibility that it is the speed relative to the medium through which it is propagating. Just as it is possible to calculate the speed of sound, and that speed of sound is relative to the medium of propagation. So the question was, what is this medium of propagation. The very notion that there was no such medium went against known thinking at the time. Most physicists assumed that there was such a medium and set about detecting it. Michelson and Morley assumed, like nearly all of their contemporaries, that the aether existed and set about do determine the Earth's motion relative to it.
So saying that the laws of physics are the same in all inertial frames does NOT mean that those same observers will measure the same value for the speed of light, just as observers in inertial frames moving at different speeds in the air will measure different values for the speed of sound in their frame. Hence, the second postulate is very much not redundant, but rather the central premise being tested.
Futurist
Joined Apr 8, 2025
952
There was no observational basis for any aether or medium, it was a hypothesis, a postulate that was unsupported by observation. I see Einstein's speed of light postulate as as a consequence rather than a necessary axiom.
WBahn
Joined Mar 31, 2012
33,357
Whether the aether or other medium was supported by observation or not is really a mute point -- the fact remained that most physicists assumed that waves propagate in a medium, and thus if you establish that light is an electromagnetic wave, that implies that it is propagating in a medium. You can look back a century later and criticize them all you want, but if you had been living at the time, I can pretty much guarantee that you would have believed the same things (as would have I and virtually everyone else here). There were some at the time, such as Ernst Mach, who argued that physics should avoid introducing entities that could not be observed. But, as a result, not only was he skeptical of the aether, but also of atoms. Many things that we know and are comfortable with today were introduced as unobserved entities that served the purpose of explaining something. Some of them were eventually observed, and some of them weren't. But even the ones that weren't served to push things along.
Also, Einstein's work wasn't in the nature of saying that the constancy of the speed of light is a necessary axiom. It was much more in the way of offering a means to test it by contradiction. Assume Postulate A. Then show that B, C, and D must follow if Postulate A is true. If you can show that B, C, or D are not true, you have proven that Postulate A is false. While this approach can never absolutely prove that Postulate A is true, the more things, particularly unexpected things, such as why we see so many muons produced in the upper atmosphere reach the surface you can show are true, the likelihood that Postulate A is true increases.
Futurist
Joined Apr 8, 2025
952
I don't recall criticizing anyone and I have no idea what I might have believed back then, evidently there were some people who didn't believe it.
I could argue some of that with you but lets not.
True, I think it's sometimes misleading today when people naively speak about the "speed of light", single it out and miss the deeper subtleties of what its actually about.
MrAl
Joined Jun 17, 2014
13,907
Seems a lot like the duality of light. doing the double slit experiment. Is light a particle thing or is it a wave thing. the simple act of observing it will and does change it's nature. So what is it particle or wave the answer is really both. that same observational shit is present with observing the spin direction Just the simple act of observing it will and does change it's spin. so you come up empty handed with no usable information from the entanglement.
Light is a wave. Sometimes I think that a 'particle' is just a man-made element made up to explain most of what we see in a simpler way than if we looked at everything as waves.
A photon can interfere with itself, only waves show interference behavior. When the waves come into contact with something else, they get absorbed and there is some transfer of energy, just like radio waves coming into contact with an antenna.
I hate the word "observed" when talking about light, because we don't have to observe anything, it happens even if we are not there anyway. To me it is more like a sort of collision.
robp1956
Joined Jun 12, 2026
121
But when the same experiment is carried out one photon at a time strange things happen that you would not expect.
Futurist
Joined Apr 8, 2025
952
Some things are explained by waves, like interference but waves can't explain the photoelectric effect, that's why Einstein created the photon model, the particle model, its often overlooked how Einstein was a founder of quantum physics, he was one of the earliest physicists to propose quantum models of light, challenging the wave model.
WBahn
Joined Mar 31, 2012
33,357
But light exhibits behaviors that contradict what would be expected if it were a wave, while being entirely consistent with it consisting of quantized particles, each carrying energy and momentum. These include the photoelectric effect, the Compton effect, the nature of blackbody radiation, and pair production/annihilation.
I don't know why you would hate the word "observed" when talking about light or anything else. I have often observed snow moving upward (because of swirling air currents). That is an observation. How does that imply that the snow would somehow behave differently if I hadn't been there?
robp1956
Joined Jun 12, 2026
121
The points I am trying to get across are the exact points this experiment shows the startling similarities between a beam of light through the double slit vs the outcome with one photon at a time however you are generating that photon usually radioactive decay. https://plus.maths.org/physics-minute-double-slit-experiment
MrAl
Joined Jun 17, 2014
13,907
Well, when the same experiment is carried out one "photon' at a time, the interference pattern is still observed. "It" continues to act as a wave.
Maybe you meant something else so you can just elaborate.
MrAl
Joined Jun 17, 2014
13,907
We might have to get a little more specific here and sorry in advance if this starts to sound pedantic, but I think that's the only way to discuss this,
The way I understand it is that Einstein did not actually create anything. He came up with an idea. The idea was to rescue physics from the predominate wave theory of light. All that was known about light at the time was the wave theory of light and it could not explain the photoelectric effect. Einstein realized that if things happened in discrete packets, it would explain why electrons can sometimes be ejected and sometimes not. The interesting thing is for some reason he decided to attribute the light itself as having a discrete behavior. I guess he decided to call it a photon, but I don't think he meant it to mean a little tiny ball entity of some sort, just a quanta, which is a certain QUANTITY of light, NOT an actual particle. I think that was what Einsteins actually meant. Somehow it got promoted to be an actual physical entity like a marble or something, and that probably stuck in because it kind of looks like it works that way. What he really meant I think was the more progressive meaning, that it is just an excitation of a quantum field.
Now what we are looking at here is what happens when light travels, which we believe is a wave at that point, and it continues to be a wave. It might be better to abandon that idea too but we should keep it at least temporarily because it is a better description than a particle at that point. What we are looking at is what happens when it hits something. The energy needed to mess with an electron significantly has to be high enough, and that means the frequency has to be high enough for the given material to actually knock out an electron. Before that however, it can still affect the electron, it just does not have enough energy to eject it.
Now let's say it has enough energy. It has to have that energy BEFORE it hits the surface. Once it hits, the electron gets ejected. But what actually changed here. The energy got absorbed by the electron, that's about it. How does that translate to the light before and/or after being a particle. Why does it have to be a particle. It doesn't, and in QFT it isn't.
This reminds me of a radio wave striking an antenna, but only loosely. The antenna absorbs the wave and that causes electrons to move in the antenna. If the radio wave turned into particles, where did they go?
Do they turn into particles for a zillionth of a nanosecond, then disappear into the electron river. Do they get absorbed by the electrons, and if so why would an electron have to 'absorb' another physical entity.
This seems to make the idea of the photoelectric effect caused by light turning into a particle during an interaction the worst possible argument for light being or becoming a particle.
I guess we could talk about this more, and look at other effects that could make light look like a 'particle'.
Also note this does not stop anyone from thinking of a photon as a particle. It's like thinking of a basketball as being a solid object when really there is air inside; it's an object but not as solid as it seems, yet we still deal with it as a basketball.
MrAl
Joined Jun 17, 2014
13,907
I explained how the photoelectric effect does not have to be explained by particles, but that is in the post before this one. We could talk about the other effects one at a time later and see what happens.
The photoelectric effect seems to have more to do with the properties of the electrons than it does with the light, but the light seems to get more of the blame. Of course it's really both not just either/or.
You're reversing the logic with the idea of something being observed. You said you observed snow moving upward because of wind, and that's fine, but that same snow would have moved with that same wind even if you were not there. So it is not about something behaving differently when we are not there, it is about it NOT behaving differently when we are not there to see it happen. That's why I don't like the word observed in the context of talking about particles and things like that. The particles (or field excitations) do not care if we are there or not, and 'observed' sounds more typical of something we are seeing with our eyes even though there is a more complete definition for that.
MrAl
Joined Jun 17, 2014
13,907
I think I know what you are getting at now. What you are describing is how the photon looks like a wave in both cases.
Maybe you meant to look at what happens when we CLOSE one slit so there is only one slit left.
