Is "off" really off in my BT speaker?
67fd4
Joined Jun 27, 2021
It has a power I/O rocker switch. When flipped in the I position, it lights up, plays ascending tones, then connects to the last device. When flipped to O, its lights go out, it plays descending tones, disconnects, then stops everything. Is O truly off?
Ya’akov
Joined Jan 27, 2019
10,295
It is very likely the switch does not interrupt the power supply to the circuit and instead is connected to an input on an MCU signaling it to disable the device.
But, there is no way to know that without seeing where the switch is connected.
ErnieM
Joined Apr 24, 2011
8,415
Define "truly."
One gizmo I made needed to be very low power except when as it was working as a battery powered pump timer. I don't remember what exact part I used but there was a LDO regulator to convert the 12V to the 5V a micro controller needed. This also worked as the power switch. The single multipurpose button on it when initially pressed would engage the shutdown pin of the LDO, which powered the micro, which in turn would then also drive the LDO shutdown pin to keep the LDO on without the user's finger until later. The very first LDO I just Googled up, the TPS709-Q1 by TI states:
TPS709-Q1 Data Sheet said:
These regulators can be put into shutdown mode by
pulling the EN pin low. The shutdown current in this
mode goes down to 150 nA, typical.
So is 150 nA (0.00000015 amps) close enough to "truly"?
rsjsouza
Joined Apr 21, 2014
430
This behaviour (tones, etc.) happening after the rocker switch is flipped to "O" tells me the switch is indeed connected to a microcontroller pin that informs it the user wants to turn it off (as @Yaakov said).
To indeed see if it is a power off, perhaps you could do a current measurement on its batteries.
67fd4
Joined Jun 27, 2021
The shutdown sequence only happens in the wireless mode. In the wired mode it instantly stops everything without tones when the switch is in the O position.
rsjsouza
Joined Apr 21, 2014
430
Ok. So one more reason to believe this is microcontroller-based control. Unless the switch between wired and wireless is also done via a mechanical switch... :)
Tonyr1084
Joined Sep 24, 2015
9,744
To determine if it is truly off when "Off" instead of switching it off and getting the descending tones, just pull the power plug. If it goes off immediately without a tone then the answer is "No, it's not fully off when 'Off'.".
My BT headphones - I have to hold the power button five seconds. Then I get an ascending tone and it comes on. When I hold the button an additional five seconds I get the descending tones. If I leave it unused for months - when I come back, it's battery is dead. Needs to be recharged.
