Is my understanding correct?
Willsy
Joined Aug 23, 2018
13
I'd appreciate it if somene could check my maths here. I'm getting confused with the units, as the numbers are small.
For this circuit:
I'd like to calculate the voltage at the point OVERFLOW_IN, and current consumed when SW2 is closed.
OVERFLOW_IN is a digital input on an MCU. VCC=5VDC. Is it just simple Ohms law?
When SW2 is closed, the path is simply from VCC to ground (assuming the MCU input is very high impedance). So:
I=V/R = 5 / 47,000 = 0.000106383 = 106uA.
Given 106uA, voltage drop across R6 is: 0.000106383 * 47,000 = 5V. Er... So the resistor drops the entire 5V? That's kirchhoff's law at work, yes?
So, when S2 is closed (and C9 is empty), there will be exactly 0V at OVERFLOW_IN, and current draw of 106uA. All 5V is dropped across R6, yes?
Is my reasoning correct? I'm wanting to consume as little current as possible when the switch is closed, ideally tens of microamps. So, for example, a 200K resistor would result in the same effect as above wrt to voltage (i.e. all 5V would still be dropped across R6 when SW2 is closed), but only 25uA consumed? Is that correct? I'm very sorry to post such fundamental questions, I just want to get some guidance to ensure I'm on the right track.
This is from a working circuit, but I'd like to reduce the current consumption. As noted above it's currently using 47K, which is up around 100uA. I see no reason to pull 100uA if I can pull 25.
The capacitor is there to stop bouncing. In real life, SW2 is a microswitch on a water tank and it is quite bouncy and wakes the MCU many times when switching. 'Slugging' it with the capacitor fixed that problem. I think increasing the resistor value will increase the time taken to fill the capacitor, yes? So I'll need to reduce the size of the capacitor.
I'd be grateful for any insights.
Regards
Mark
danadak
Joined Mar 10, 2018
4,057
Yes when SW is closed OVERFLOW_IN essentially forces to 0V, actual V
is related to current and its contact resistance when on, usually in the
mOhm range.
Capacitors to debouce not prefered method. Normally thats done in software,
or if micro has a HW debouncer using that. A cap and a high valued pullup like
you have raises risetime, therefore time input forces CMOS input structure to
draw current, potentially a lot of current.
http://www.ti.com/lit/an/scba004d/scba004d.pdf
Attached methods to debounce.
High valued pullups have two problems, leakage current can cause them
to develop an unwanted logic level, and they are susceptible to noise
coupling due to their HiZ.
Regards, Dana.
38,827
"Slugging it" with a capacitor like that across the contacts, will cause a high surge current when the contacts close, which errode the contacts and possibly cause them to weld together.
Do the debounce in software, as Dana suggested, so that it only responds once for a give period of time when the switch closes.
