Is my C upside down ?
TQFP44
Joined Sep 3, 2016
51
Having come to C programming (PIC and XC16) from assembly and previously basic, it is easy to have possible "bad" habits when laying out code in the editor, my question relates to having the sequence of code 'areas' , ie definitions , includes , main , functions , etc does it matter , this occurred to me as my C book said , C does not need and END statement , as it uses the last brace in main(); ... all my stuff has main is at the start before the functions.
joeyd999
Joined Jun 6, 2011
6,456
C is entirely free-form, so you can obfuscate your code to your heart's desire.
The only caveat is that external functions and variables must be declared prior to invocation, usually by including a header file at the top of your C code.
As you write, consider that someone else may need to read and understand your code later.
dannyf
Joined Sep 13, 2015
2,197
It really doesn't matter. In a real project, most of your code will be in various .h and .c modules anyway. A typical main.c file for me contains high level logic.
With that said, I typically write my main() towards the end of main.c, to save prototyping.
MrSoftware
Joined Oct 29, 2013
2,273
Do some googling for an explanation of the C and C++ compilation process. Understanding the various steps of compiling your C code into a binary will answer your questions about where things have to go and why.
33,135
As with most things, there are various schools of thought. Probably the most important thing is to adopt a rational style and then use it consistently. This will not only help you code more efficiently, but will aid others that have to review/maintain your code -- even if your style doesn't resemble their style, they will be able to quickly determine what your style is and then use that to aid in interpreting your code.
I prefer putting functions that rely on other functions later in the file. Not only does this avoid prototyping from a convenience standpoint, but it means that you can't (for functions in the same file) end up with accidental indirect recursion without the compiler at least throwing a warning.
I also try to put into the header files only those things that are required by the code that is going to use them. This is consistent with the principle of least privilege.
