no because first i use voltage divider than add series resistance .Does your pc speaker jack still work?
Did it release the magic smoke?
how to increase it frequency?Yes it's Sinewave smoke!!!
Digital to Analog Converter (DAC) converts digital values into analog signal, then analog signal is sent to speaker.ok i found this in quick search in google
http://www.nch.com.au/tonegen/
how it generate sound..cool how it generate sound in digital computer??
It is if you like listening to 50 or 60 Hertz noise, depending on your country.Is this Sin wave audio??
That's affectionately known as "60-cycle hum" and is usually a bad thing in audio equipment, since it is a symptom of power supply noise getting all the way through to the speaker. A normal audio amplifier filters this out so that the audio signal is the only thing reaching the speaker.Hello,
Is this Sin wave audio?? i have connected the transformer 24V AC output to my pc speaker audio jack.
How sin wave triangular saw toth waves are generated in digital?Digital to Analog Converter (DAC) converts digital values into analog signal, then analog signal is sent to speaker.
You think ?FFS this can't be a human
