Is it possible to modify a power wheelchair charger as voltage adjustable?
Alec_t
Joined Sep 17, 2013
15,170
Not sure what you're asking. A smart charger will adjust voltage and current to give a correct charging profile for a particular battery chemistry.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
I may shouldn't use the word 'smart', it is a charger, my question is if it is to modify it's voltage variable which is fixed now.
Dodgydave
Joined Jun 22, 2012
11,395
Are you wanting to use it as a separate PSU for something else , ?
The usual way to alter the voltage is to change the feedback resistance to the optocoupler, but as yours is controlled by a Pic, it might be difficult.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
You are right, I saw some one convert a laptop power supply into a variable voltage source, I think the Pic may take a feedback from the battery be charged, but there are only two wires.
