Is it a Sziklai Pair?
switch626
Joined May 9, 2020
5
I am trying to identify the circuit configuration of Q11 and Q13 (Q12 and 14 by extension). It looks like a Sziklai pair but I've never seen a resistor (R50) attached where it is. Is it a Siklai? and is R50 for temperature stability/negative feedback. Thanks.
Scribble
Papabravo
Joined Feb 24, 2006
22,111
Yes, they appear to be. Don't know about the resistor. Normally the outputs would be capacitively coupled to the output. What are the resistor values?
Papabravo
Joined Feb 24, 2006
22,111
My only other thought is to prevent an overlap in on-times from produceing a power supply short. 94 Ω for a shot period of time won't affect the AC performance. The Sziklai pair only requires a single diode to prevent crossover distortion unlike the Darlington pair equivalent.
switch626
Joined May 9, 2020
5
That hadn't occurred to me but makes sense. Thanks.
