Is it a bird, is it a plane, is it ....... ?
Alec_t
Joined Sep 17, 2013
15,121
Why would TI choose to give two completely different types of IC the same code number?
This must have caused considerable confusion over the years.
Anyone know of any other ambiguous IC numbering?
botey
Joined Oct 4, 2016
35
LOL I think it is because the parameter values for the output swing voltage and the input voltage range are slightly different. One could say they are identical twins dressed in a different way. The difference is almost negligible.
Alec_t
Joined Sep 17, 2013
15,121
Do you really see a quad opamp and a single low-dropout voltage-regulator as being 'identical twins'? I think it would take more than I/O voltage ranges to make them that.
ErnieM
Joined Apr 24, 2011
8,415
If you follow those link at:
LM3403 | Single Channel LDO | Linear Regulator (LDO) | Description & parametrics
You will find this device:
LM3403 (OBSOLETE)
Quad Operational Amplifiers
The LM34023 was, is, and always shall be, a quad op amp. The search engine running for T.I. is a bit confused, that is all.
No manufacturer would reuse part numbers like that.
botey
Joined Oct 4, 2016
35
Wait a minute. I'm confused haha. I thought both of them are quad op-amps. I didn't know LM3403 was a voltage regulator before. This is indeed confusing.
