Is 5V tolerant the interface (rx, tx) of this module SIM900?
ericgibbs
Joined Jan 29, 2010
21,567
hi 92,
Checking the specification I would say that the module requires a 5V/3.3V level shifter between the Arduino and Module UART lines.
If you Baud rates are low, I have used 2k/3k3 resistive level shifter for sending to GPS module and a 10K pullup on the GPS output line.
E
EDIT:
I use these modules for faster transfers, will run at 20MHz on SPI.
https://www.amazon.co.uk/MagiDeal-C...=8-3&keywords=5v+to+3.3v+level+shifter+module
