Is 3 via's enough
K0ld
Joined Jan 16, 2023
3
Hi, im making a small pcb for conecting af usb device and a powered usb hub.
This is my first pcb and im not sure if 1 via or 3 vias is enough for for power and grounds.
I have tried calculating it, but im still not sure.
Any help would mean alot
K0ld
Joined Jan 16, 2023
3
On my boards, I tend to go the way of multiple small vias myself
So my version with the 3 0.3 mm vias can carry around 2.3 amp. Do I then just add the 3 up, and get 6.9 amp (nice). That should be enough for usb power delivery. I should also be able to make them smaller.
Is that right?
34,828
For USB current of 500mA, one via will do.
Better yet, use a plated through pad. For higher current, solder a wire in the hole.
sagor
Joined Mar 10, 2019
1,050
The pad(s) seem large enough compared to the trace leading to the pad. If concerned about the capacity of the pads, have you calculated the current capacity of the traces themselves?
K0ld
Joined Jan 16, 2023
3
It was just the easyest place to show it, so just used a data conection to demonstrate
