Is 100 Watts at 8 Ohms same as 100 Watts at 4 Ohms?
bypassrestrictions
Joined Jun 1, 2021
107
I have an old home theater system, for some of it's speakers it says 100W at 4 Ohms, for some other speakers and subwoofers it says 100W at 8 Ohms. Is this same? Or is there some mischief going on.
Ian0
Joined Aug 7, 2020
13,317
The 100W/4Ω amplifier gives 20V rms output. If you connect an 8Ω sepaker to it, you will get 50W, and it will be 3dB quieter*.
The 100W/8Ω amplifier gives 28V rms output. If you connect a 4Ω speaker to it, you will overload it.
*If it is an amplifier with a switched-mode power supply. An older amplifier with a 50Hz transformer will give slightly more power because the power supply voltage will rise at low load, so perhaps you might get 65W and it will be only 2dB quieter.
The sensitivity of speakers will vary from about 84dB @1W@1m for a tiny pathetic modern one in a tacky plastic case, made as cheaply as possible, to about 115dB @1W @1m for a horn-loaded enclosure from the 1960s.
