IRFZ44N mosfet gets destroyed in induction heater
Avoy S.
Joined Apr 12, 2025
I am making an induction heater. mosfets irfz44n, c = 0.1uf, r1=r2=220ohm, l1=l2 (don’t know I made it by myself but it’s greater than the induction coil. I made it using 24awg wire, 30 turns around small transformers core), vsup is 12v, the induction coil I am using is 5 turns coil (around 3.382 micro henry, c=0.1uf and resonance frequency 158khz). The circuit runs at 158khz.
My power supply can go upto 5amps.
I used zener diodes 5V 1/4W with 1Kohm resistance. It lowers the gate voltage and mosfets heat less.
The problem is while I tested the circuit in breadboard it performed well but when I connected it to pcb one mosfet damaged (I checked the gate-source continuity and it showed that gate source are shorted).
how can I fix it?
Beau Schwabe
Joined Nov 7, 2019
186
"...It lowers the gate voltage and mosfets heat less" ... that doesn't sound quite right See Fig3 page 3 (https://www.digikey.com/en/htmldatasheets/production/73742/0/0/1/irfz44npbf)
Those Zeners should be 15V ... not 5V
If the Supply is less than 15V , such as your case, you can actually omit the Zeners and 1k resistors
r1 and r2 could be a little higher 470 Ohm or 1k
The diodes that you don't have labeled need to be in place
There is also a "stall" condition if the components are very close in value. Not likely, but sometimes happens. Place a 10k resistor in parallel with R1 or R2 (NOT both) to form a slight imbalance.
Avoy S.
Joined Apr 12, 2025
Are zeners limiting something or it is fine to keep it?
And
What is the purpose of increasing r1 r2 ? Is it to decrease the gate current? Or any benifit to oscillation?
Beau Schwabe
Joined Nov 7, 2019
186
The Zeners can add parasitic capacitance that can slow down the switching On/Off time of the mosfets (you want the mosfets to switch as fast as they can) .... increasing r1 and r2 ensures the imbalance will be greater, thus minimizing a stall condition on startup. The mosfets require so little gate current that a higher value resistor here won't be a problem. That said you want just enough so that there is a small imbalance. The imbalance ensures that one mosfet will turn on slightly sooner than the other one and initiate oscillation.
