IRDA Transreceiver functional help
akash_sr
Joined Aug 28, 2017
We are using TFDU6103 IRDA Transreceiver for data transition. We transmitting the data through IR Laser and TFDU6103 receiver will receive the data and process it. In the part of testing we faced a problem of unwanted continuous pulses are generating when we touch the top of the receiver component .
This causes this Transreceiver is not working in out door when sun light falls on the receiver, Can you give any solution
DickCappels
Joined Aug 21, 2008
10,662
Things to try first:
For the continuous pulses when a hand touches the top of the receiver, try putting a ground conductive shield over as much of the transceiver as possible.
As for sunlight, IR bandpass filters should help.
#12
Joined Nov 30, 2010
18,224
If you must place the receiver in sunlight, place a shield over it to stop sunlight from falling on it.
A laser is very directional so aiming a simple paper tube at the transmitter might be sufficient.
akash_sr
Joined Aug 28, 2017
Thanks DickCappels,
we will try the ground conductive shield option and the transceiver itself have internal band pass filter
