ir2110 drive boost converter issue
mah
Joined Mar 15, 2010
393
i used ir2110 to drive boost converter (low side switching) but when i connect the source input it make short circuit and the dc source turned off. i don' know the reason i simulate it on Proteus and it works fine.
note; i didn't find ir2110 in proteus so i used ir2112( they are the same )
mah
Joined Mar 15, 2010
393
I used pc power supply to source 12v,5v for the ir2110 and also as input source for the converter at 12v
Orson_Cart
Joined Jan 1, 2020
110
It's clear you have limited experience in power electronics, buffer needed to supply the current peaks necessary to turn the fet on and off efficiently - also for non logic level mosfet, buffer / level shifter needed to go from 3v3/5V of the uP to the 12 or 15V needed to take the fet into fully saturated turn on
despues de 10 años transcurridos, debiste de haber resuelto el problema..
saludos
Moderation: Please use English text.
After 10 years, you should have solved the problem.
Cheers
kaindub
Joined Oct 28, 2019
179
I guess 30 years Power Electronics experience is not enough.
