The comparator must trip ~ halfway between those two voltage levels.
No, the delta change in illumination between a white dot and black dot is just a few %. The current through the phototransistor will be 100s of uA, e.g. 150uA, so with a white dot you might have 150uA, and with a black dot e.g. 140uA, so the two voltage levels might be only 10s of mV different....When the Phototransistor will be over the dot then it should be OFF...
