Hello everyone,
I want to build a circuit that can sends IR signals through an IR LED at about 38 KHz carrier frequency.
Once I set up the 555 timer to generate the continuous 38 KHz signal, how can I create bursts every time I hit a pushbotton, or send a signal from a MCU ?
I tried using a NPN transistor as a switch that takes the external signal from the base and the 38 kHz signal to the collector, but it doesn't work.
Is it possible to do so still using the 555 or should i do everything on software? (I would like to use the 555 timer to learn more about hardware instead of software)
Thank you in advance
