Iodine and solution concentration.
Teljkon
Joined Jan 24, 2019
267
I accidentally left the cap off a bottle of Iodine tincture and other than just staining my wall it condensed a bunch. I am wondering if it is still safe for day to day use on cuts, scrapes, and bites? I think just the the alcohol evaporates out if I am not mistaken.
Thought someone here might know a little more chemistry than me.
SamR
Joined Mar 19, 2019
5,533
Sure, it's just a tad less iodine in the bottle. I used to keep a small capped bottle of iodine crystals on the lab shelf for making nitrogen tri-iodide and over the years there was a huge iodine stain on the shelf and walls for over a meter in every direction from the small bottle.
MrSalts
Joined Apr 2, 2020
2,767
Solid Iodine 'evaporates' too - sublimates - at room temperature.
I think you mean
solid iodine evaporates too?
I don't think the iodine evaporates from an alcohol alcohol. Iodine preferred to stay dissolved in the solution and only starts vaporizing (subliming) once the alcohol dries out.
Halfpint786
Joined Feb 19, 2018
109
I keep my iodine in a glass shaker tube with HDPE cap and teflon seal and aluminum tape covering the glass so light don't get in. It looks the same as the day I put it in there 6 years ago.
Paint the wall. It isn't worth your time trying to scrub it off. Even if you do turn it into a soluble salt with a base, sunlight will separate it again. And heating it off will just drive it elsewhere (including your lungs).
Dave Lowther
Joined Sep 8, 2016
347
You can try placing a box of of ice (cold metal surface in the carbonate and hitting the walls with a warm hair dryer or hot air gun set in low to vaporize the iodine.
Those pictures are from 1-2 years ago. I did clean with a cloth as best that I could and then painted over it with some sealing paint then a coat of regular paint. It's fine now, no iodine showing through the paint
