Does anyone has the hardware cicuit of inverter with 555 timer
cant i build ups with the simple inverter?You have started several threads on this topic or along the lines of building a UPS. Something you need to consider is most of the simple circuits where a transistor pair is used driven by an oscillator output are not going to give you much current. Should you wish high current from an inverter you should look at high current inverter designs and in most cases it is easier and less expensive to simply buy an inverter or UPS off the shelf. Just something to consider.
Ron
That depends entirely on what you need to power, which you have not specified. The simple circuit such as the one I showed is unlikely to support more than 1W at the AC load.cant i build ups with the simple inverter?
I guess that all depends on how we define simple. You build a UPS based on what the power demand will be. Most people who want for example a 1,000 watt (True Power) discover it is easier to buy than build. There is also a matter of the waveform one expects. Most relatively crude UPS units output a MSW (Modified Sine Wave) and the higher end units output a TSW (True Sine Wave) so that is a consideration, here is an example. I see Wayneh has weighed in as I type. So the needed power is a very big consideration. Also you may notice larger units also use 24 VDC verse 12 VDC and there is good reason. 1,000 watts, which is not much, at 12 VDC is about 84 amps and that does not take into account inefficiency so figure upwards of 100 amps draw on the DC supply while a 24 VDC supply reduces that by 1/2 to about 50 amps.cant i build ups with the simple inverter?
Overcurrent protection using comparator in inverter | Power Electronics | 4 | |
| D | 556 dual timer 12 volts to 110 or 220 volt inverter | General Electronics Chat | 5 | |
| J | 555 timer inverter | Digital Design | 13 | |
| A | 555 timer inverter | Digital Design | 18 | |
| R | 555 Timer, AC to DC Inverter | Digital Design | 5 |
