Inverter and Rectifier for 13.56mhz
Papabravo
Joined Feb 24, 2006
22,111
The following application note suggests the possibility of doing what you want to do without the necessity of building RF type circuits which can be a challenge for experimenting.
https://www.analog.com/en/design-notes/wireless-li-ion-charger-solution-for-wearable-devices.html
The application note describes a VCO (Voltage Controlled Oscillator) that excites an LC tank circuit that can transfer power across a small air gap. Here is a simulation of that circuit using ideal components. Using real components will probably not be quite as good, but it seems like 50% might be achievable.
BobTPH
Joined Jun 5, 2013
11,645
Are you saying you have a device that charges wirelessly at 13.56 MHz? If so, please link us to the specifications.
I am skeptical, wireless phone chargers charge at around 100 KHz, I would be surprised if both frequencies are equally usable.
Unless maybe you are talking about hearing aids, the small size might dictate the higher frequency.
