Question about replacement of Bridge Rectifier of Monitor PSU/Inverter board
UnnamedUser159
Joined May 3, 2016
501
If i watch pdf of this board
715g813-1 Ver:C i see
U4KB80R 800v/4a
Where i keep stuff from this monitor i have pbl405 which should be faulty(desoldered from the board) and one working gbu405.
The questions :
why in documentation there is diode with 800V but on board most probably was 600V
i will put the 600V. If something goes wrong only BD will goes faulty or not?
thanks
UnnamedUser159
Joined May 3, 2016
501
and the next question - shorted fr107. In the shop they had not such.
Fr107 is fast recovery rectifier 1000/1
1n4007 is only rectifier 1000/1
Will it do the job?
dendad
Joined Feb 20, 2016
4,635
There is no real reason not to put a higher voltage bridge rectifire in there. I would not use a 400V one on 240VAC supply. That does not give enough headroom for tranzients. Higher is better. It giver you a more robust power supply so it should be more reliable.
