Hi
Please help
I have an exam in less than 24 hours and really need the solution of this problem.It might not be a practical circuit but I need the solution .
Problem statement:
Supply voltage E = 100 V and the transformer turns ratio Ns/Np = 2.The inverter's switching frequency is 2 KHz and its output is a symmetrical square wave as shown.The load current is 8 A(DC) with negligible ripple.
Each thyristor has a control angle of 40 degrees.The transformer leakage inductance is represented by L=0.25 mH.
neglecting the transformer magnetizing inductance and its primary and secondary winding resistance and assuming ideal devices, calculate the average currents in the transistors and diodes(of the inverter).
________
I need the primary current waveform and in witch parts of it the transistors and diodes are on.
Please help
Problem statement:
________
