Interfacing with an LCD Screen
HarG
Joined Nov 20, 2012
18
Hello everyone,
I'm trying to operate a 2-line LCD HD44780. I am just wondering if I need to set EN high to low for every command I send? Also if I just write the initialisation piece, will I notice if it has worked on the display (like a flashing cursor) or will it stay blank until an actual command has beed sent?
Thanks
ErnieM
Joined Apr 24, 2011
8,377
Yes it needs to toggle low then high for every command.
Stays blank till initialized. If you have a contrast control you sometimes see half the rows show as complete blocks with a very misaligned contrast on an uninitialized display.
HarG
Joined Nov 20, 2012
18
Hi guys.
Been having a go with it and can't seem to get it going. I think I have about got it but could you just take a quick gander at my code to make sure I'm not hugely mistaken?
I set a delay of 2ms (as its just larger than the longest time for the display to do a function) instead of using the busy flag. I can't see the problem really. I have the 8 data bits in Port C of an 18F45K20.
Rich (BB code):
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#pragma config FOSC = INTIO67, FCMEN = OFF, IESO = OFF, PWRT = OFF, BOREN = OFF
#pragma config BORV = 18, WDTEN = OFF, WDTPS = 1, MCLRE = ON, HFOFST = ON
#pragma config LPT1OSC = OFF, PBADEN = OFF, CCP2MX = PORTC, STVREN = OFF
#pragma config LVP = OFF,  XINST = OFF, CP0 = OFF, CP1 = OFF, CP2 = OFF
#pragma config CP3 = OFF, CPB = OFF, CPD = OFF, WRT0 = OFF, WRT1 = OFF
#pragma config WRT2 = OFF, WRT3 = OFF, WRTB = OFF, WRTC = OFF, WRTD = OFF
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF
#pragma config EBTRB = OFF
#define LCD_data PORTC
#define RS   RB5
#define RW   RB6
#define EN   RB7
#define _XTAL_FREQ 16000000
void PIC_init()
    TRISC=0;
    TRISB=0;
void LCD_busy()
  __delay_ms(2);
void LCD_init()
     LCD_data = 0x30;
     EN   = 1;              //Enable H->L
     EN   = 0;
     __delay_ms(4.5);
     LCD_data = 0x30;
     EN   = 1;
     EN   = 0;
    __delay_us(300);
     LCD_data = 0x30;
     EN   = 1;
     EN   = 0;
     LCD_data = 0x30;       //Function set
     RS   = 0;
     RW   = 0;
     EN   = 1;
     EN   = 0;
     LCD_busy();
     LCD_data = 0x08;       //Display off
     RS   = 0;
     RW   = 0;
     EN   = 1;
     EN   = 0;
     LCD_busy();
     LCD_data = 0x01;       //Clear LCD
     RS   = 0;
     RW   = 0;
     EN   = 1;
     EN   = 0;
     LCD_busy();
     LCD_data = 0x03;       //Entry mode - increment, shift left
     RS   = 0;
     RW   = 0;
     EN   = 1;
     EN   = 0;
     LCD_busy();
void main(void)
     __delay_ms(20);
    PIC_init();
    LCD_init();
    RS = 1;
    RW = 0;
    LCD_data = 0b00110000;  //'0' ASCII
    EN = 1;
    EN = 0;
    LCD_busy();
    RS = 0;
    LCD_data = 0b00001111;  //display on, cursor on, blink on
    EN = 1;
    EN = 0;
spinnaker
Joined Oct 29, 2009
7,830
Instead of us looking at your code, you should first verify that everything is connected the way it should be and pins are changing state as expected.
You can do this by single stepping through your code and measuring the pins on the LCD with a scope, logic probe or voltmeter. You can make a logic probe with an led and resistor if you don't have one.
One of the biggest problems of an LCD not working is improper connections.
Many compilers have LCD libraries and there really is not need to write one. Also many out there on the internet.
ErnieM
Joined Apr 24, 2011
8,377
Check the delays you use. I did notice you immediately bring EN hi then lo. It may need a bit longer dwell, as well as setup times for the data.
HarG
Joined Nov 20, 2012
18
Thank you very much guys. I will have another go tomorrow and let you know how it goes.
Once again thank you.
HarG
Joined Nov 20, 2012
18
Hi guys,
I had a bit of a go with it tonight. I changed the 8 data lines to LEDs to try and see what is going on. They seem to be doing the right thing but unfortunately they are continuously looping.
I was under the impression that if I did not put a while(1) command in the main program it would only run once? It seems to be continuously running through my main program.
Any thoughts?
30,824
If your main program is being repeated check to see if the watch-dog timer is active and hence restarting your program after a predetermined time-out.
ErnieM
Joined Apr 24, 2011
8,377
Hi guys,
Any thoughts?
The opposite is true, though it depends on how and where you insert the while(1)
